Go to Post Do not worry about the VEX camp versus FIRST camp issues. It is a huge marketplace. It is only about 4% penetrated. There is room for everyone. And competition is good for the consumer. - ebarker [more]
Go Back   Chief Delphi > Technical > CAD
Unread 04-04-2012, 22:52
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Autodesk Inventor Sheet Metal Question
My team uses Autodesk Inventor to CAD our robots. Since we were able to get lasercutting donated this past season, we used the sheetmetal tools in Inventor. Throughout the season I was constantly frustrated with one thing: Everytime that I created a new sheetmetal part, the "default" style (with the material, sheetmetal thickness, bend radius, etc.) would change, even though I would change the default to what I wanted and then saved it. I have the Styles Editor set to "Read/Write" as well.
Have other teams encountered this problem? Does anyone have a solution to keep the default from changing. It was such as pain this seasons because I literally spent half of my time constantly changing the settings to what I needed when it wouldn't just stay the same. Any help is appreciated.
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 05-04-2012, 00:21
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: Autodesk Inventor Sheet Metal Question
(first off, this probably should have been made in the inventor subsection)
If I remember correctly (haven't use inventor in a few years so I may be running on old info) you have to set it up to load the settings from the correct save file. The settings you have set may be loading from the wrong save file when you open a new file.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 05-04-2012, 00:43
Thanks for the help. You are correct - I had clicked the save button in the styles editor but didn't actually save in to the styles library. What I had to do was right click on default in the navigation bar on the left and click "save to styles library." This fix will save me much time and hassle. Thanks!
Unread 05-04-2012, 08:16
Peck's Avatar
no problem
TEAM 1619
