Go to Post "Mother nature does not give partial credit" -Woodie Flowers, Kickoff 2003 - TerryDolan [more]
Unread 05-04-2012, 11:34
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
3/8 Hex Hub?
Hello all,
We are looking to convert our shooter to hex, but it seems AndyMark only has 1/2 hex hubs. And I believe the 1/2 inch is a over kill for our application, so does anyone have an solution to drive an AM Plaction wheel with an 3/8 hex?
I am thinking it may be best to get an 1/4 hub and then drill/broach it out for 3/8 hex but we don't have any broach tools.... yet
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 05-04-2012, 11:47
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Re: 3/8 Hex Hub?
i had this same issue awhile ago... the is almost nothing commercially available with a 3/8" hex broached in it. if you aren't short on weight go with the 1/2", but if you are short on weight you could always go with a hollow 1/2" shaft.
Unread 05-04-2012, 11:55
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: 3/8 Hex Hub?
We modified AM-0134 (3/8" keyed hub) by running a 3/8" hex broach through it using an arbor press. The broach is similar to McMaster p/n 2875A19 (~$145/ea) but you can probably find one cheaper.
Richard Wallace
since 2003
Unread 05-04-2012, 12:57
Mk.32's Avatar
AKA: Mark
Re: 3/8 Hex Hub?
I am wondering if we could get a hub 3d printed on an Dimension Printer...
For a shooter wheel I would think it is strong enough.
Unread 05-04-2012, 13:31
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Re: 3/8 Hex Hub?
It should be fine if you don't expect very high acceleration on your shooter, like sudden stops from full speed or sudden jumps to speed. Software/electrical things you could do is filter the speed output and set the motor controller to coast.
If your printer is like ours and gives you options in print density, make sure you choose the highest density possible.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 05-04-2012, 13:37
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: 3/8 Hex Hub?
You could press a 3/8" standard socket into a .500 keyed hub (bore or turn one or the other to fit). Aside from the fit, weight, reliability, alignment and complexity problems relative to just going with a .500 hex........
Unread 05-04-2012, 16:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: 3/8 Hex Hub?
If you have a CAD model, I can 3D print you a hub, or if you want to send me a hub with a smaller bore, I could broach it 7/16" hex and send it back to you.
