Go to Post Never underestimate the power of human ingenuity. - Wetzel [more]
Go Back   Chief Delphi > Technical > CAD
Unread 05-04-2012, 14:28
bam-bam bam-bam is offline
bam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond repute
Any CAD alternative options?
Hello all-
Before I moved, I had Autodesk Inventor available as a school resource. However, that resource was recently taken away because I had recently moved, and my school does not offer CAD/PLTW as a part of their school curriculum.
I'd like help more on CAD for my team, so are there any alternative resources where I can run CAD?
I have a computer capable of running Inventor, but I share this computer with my sister, consequently running out of memory required for Inventor. Does this mean I need a new computer entirely?
Unread 05-04-2012, 14:32
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Any CAD alternative options?
If you are associated with a school, you should still be able to get autodesk inventor through students.autodesk.com.
Unread 05-04-2012, 16:21
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
FRC teams can get it for free at the start of every build season simply by asking for it.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 05-04-2012, 19:34
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Not sure this will help but:
https://www.autocadws.com/web
Unread 05-04-2012, 19:43
That was an option I was thinking on.
Do you know how long the software lasts? I read somewhere that it lasted for about 3 years or so (I am fairly sure that I am wrong).
Unread 05-04-2012, 21:18
Joe G.'s Avatar
AKA: Josepher
It lasts a year. But since they put out a new version every year, you effectively have infinate time with the software.
Unread 06-04-2012, 16:36
Sorry, I wasn't clear before, but I meant how long the software lasts on the computer before it expires? (i.e. 30-day trial, but seems you can renew with a serial number)
Unread 13-04-2012, 23:34
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
All Autodesk software initially installs in 30-day trial mode to give you a chance to get it running correctly before activating your free 3-yr student license.
Each year you can download new release so in effect you have a free student license for as long as you are a student.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
