Go to Post Oh, for the days of 30-page rulebooks! - EricH [more]
Unread 06-01-2003, 00:03
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Autonomous Initilization
I am curious. If we wanted to have several different options for our autonomous 15 seconds, could there be switches on the OI for choosing between them, or would the switches have to be on the RC? I think that, to run, the OI will have to be in communication with the RC anyways.
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 06-01-2003, 00:08
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
The OI needs to be in contact with the RC, but nothing it sends gets input into your code.
Basically, all the axes are set to 127 and all switches are set to off. Thus, the switches would need to be on the RC.
Unread 06-01-2003, 22:17
VanWEric VanWEric is offline
#0250 (Dynamos)
VanWEric is an unknown quantity at this point
during autonomous mode, does the reset switch still work? if so, does it reset the RC, or just the OI?
Unread 06-01-2003, 22:48
Wayfare Wayfare is offline
Wayfare is an unknown quantity at this point
Send a message via AIM to Wayfare
So how exactly will the autonomous mode be switched off? This may have been answered before, I haven't checked through all the threads yet.
Unread 06-01-2003, 23:02
iscrc2 iscrc2 is offline
#0568 (Nerds of the North)
iscrc2 is an unknown quantity at this point
There is a bit that you test in code that tells you when the game is in auton mode. If you don't test for it it basically looks to your code like your OI is idle. The innovation first manuals describe how to test for it in code.
http://www.innovationfirst.com/first...ence_Guide.pdf
Unread 06-01-2003, 23:50
FRC Key Volunteer Trainer
AKA: CrazyNate
Considering that the only way we have control over the autonomous mode is to change the team number, which can obviously not be done at competition, I'm guessing that the competition port/arena controller will be sending the signal to the OI as to whether to run in autonomous or user-controlled mode...
Nate Smith
nsmith@smythsoft.com
Unread 06-01-2003, 23:51
Morgan Jones Morgan Jones is offline
Morgan Jones is an unknown quantity at this point
I'm working from memory, here, but I think the reset button on the OI resets the RC (as I think that's the only thing that would ever need resetting). I would assume that the reset button would work during autonomous mode because its not an input your program would read. It is a command intercepted by some other controller in the RC that would then initiate the reset sequence.
Morgan Jones
Team 578: Fairport High School/Gleason Works
Unread 06-01-2003, 23:58
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
yeah, anything PLUGGED into the OI will not work. anything BUILT into the OI will work. that includes the E-Stop button for obvious reasons.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 07-01-2003, 00:06
Half true. There's two resest buttons on the OI--one resets the OI and the other resets the RC.
Unread 07-01-2003, 18:35
#0250 (Dynamos)
then i guess we have our prog switcher right there. each time you reboot, pick a dif program. Replace the bat volt with the prog id. or something like that
Unread 08-01-2003, 00:08
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
there's sample code in the manual for it to automatically switch...
just look in there under the different modes...it has the EXACT code you need
if anyone has any trouble, feel free to contact me via PM or IM or e-mail
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 08-01-2003, 00:24
John Prather John Prather is offline
#0234 (Cyber Blue)
John Prather is an unknown quantity at this point
Send a message via Yahoo to John Prather
First of all, you will not be able to reset the robot using the OI control because that switch is still based on radio trasmission to work. So you would also not be able to switch programs bassed on changing the batt volt to a program id because it will not transmit to the robot. To program autonomous mode you will have to use switches on your robot or just change the program before you get to the field based on the robots and teams that you are up against. You can always set the starting values of the speed controlers or the spikes though the program. This is also another way to program the autonomous mode.
John Prather
Team 234
Student/Electronics/Controls/Programs/Scouting Team
Unread 08-01-2003, 12:47
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
I agree...a switch or two on the "on board black box" circuit board should do the trick
Don't PANIC!
S. P. A. M.
Unread 08-01-2003, 14:09
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
There will be radio communication between the OI and the robot during autonomous mode. I haven't checked yet if the reset button works in autonomous mode, but my guess is that it will, because the reset command is handled by the master processor, not the BASIC stamp. Remember, the robot won't do anything at all (autonomous or not) without a valid radio link.
Unread 08-01-2003, 17:19
Mike537Strategy Mike537Strategy is offline
#0537 (Charger Robotics)
Mike537Strategy is an unknown quantity at this point
What I have heard is that your controls (Joysticks and such) won't even be turned on by the judges until the 15 seconds are over. So I'm guessing all the control systems are plugged into a system that keeps them off for the 15 seconds, just like the system that activates the robots when all 4 pads are being stood on.
"Charging into the future, one game at a time." - Team 537 motto
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous location manodrum Programming 4 02-04-2003 08:05
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
