Go to Post "And that right there is the Sharpie line between right and wrong. Guess which side you cut on?" - Cypher [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 04-03-2012, 17:26
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Re: Robot Cart
Todd,
Can you tell me more about the base of this cart? Did you buy it or is it all custom? I really like this design!
Originally Posted by ToddF View Post
We have an aluminum platform cart with a removable handle.
Attached to the deck are two 8020 cross bars. On top of those are two longerons. On the longerons are posts that support the robot. By adjusting the locations of the longerons and posts, we can fit the cart to each year's robot. The height of the posts are set so the robot just clears a standard doorway. If necessary, the posts can be trimmed or swapped out to increase or decrease the robot height.
As shown in the pic, the crossbars and longerons also make a convenient place to stick stuff when working on the robot.
The cart design is evolving. Last year the height was great for standing and working on the robot, but we couldn't go through doors. This year, we dropped the post height to fit through doors, and the robot ends up at the perfect height to work on while sitting in a chair.
Next step is to add stowage for the operator console, tools, and water for competitions. We had stowage for bumpers last year, but may leave them off the cart this time.
FRC 2656 | FTC 5526 | VEX 9656
Unread 06-04-2012, 10:43
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
Re: Robot Cart
We made ours with 1/16 wall 1" steel square tubing that was student welded. A set of EXTRA BEEFY mecanum wheels that make it a breeze to maneuver and some nice bearings that allow it to be pushed in any direction with one finger while having 400 lbs on its bed. It can have 12 batteries on board and nice tool set. It can handle a 4" high wire bump with ease. It has adjustable rails that the robots' dead axles sit on so we cant test the drive train and easily work from under the robot. It soon will be motorized and will use 4 AM Super Shifters that have a gear taken out of them so we can shift into neutral to make it really easy to push. It'll also have underglow and headlights for loading/unloading at night. But one of my favorite feature's is that with the removal of two pins that hold a rail on, you can flip up part of the middle tray and it becomes a comfy 2 person couch (it'd be really fun at demo's!) perfect for the practice field and when our drive team is exausted. Still no pictures, but there coming.
We make easy things look difficult, everyday!
Unread 06-04-2012, 14:10
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Re: Robot Cart
Our students built a new cart shortly after the stop build date. The design is alot like ToddF's pictures, except a bit longer and shorter (it fits under doors). They made a simple frame out of PE20 aluminum (I think thats what it was); put lexan on the bottom of the frame along with a pad so someone could climb under the robot and work (or nap; it even has an elevated piece of lexan with a headrest), we can store bumpers, balls, batteries, and/or drivers station down there too when it's queueueueing time.
The lengthwise supports are adjustable easily enough (for forward compatibility), and support the robot by the frame instead of the wheels, so the wheels can spin freely.
We also attached some PVC tubes as tool/flag holders.
Unread 06-04-2012, 14:59
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Re: Robot Cart
Although I unfortunately don't have pics right now our cart is all custom. Our welders bent some 1 inch tubing to make a base that's wide and long enough to hold three bins plus our driver station and a battery on top of the bins, then an elevated U-shape bent from the same tubing. The U-shape is the width of the inside section of the C-Base long configuration frame, so the robot rests there. The wheels can free spin there, and we used it for testing motors often.
We have two simple lcoking casters and two fixed wheels, larger than 6 inches to get over the cord bumps at MN North Star's venue. The casters were from Minnesota Casters, a distributor in MN. Gotta love our sponsors.
Unread 06-04-2012, 17:08
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
Re: Robot Cart
We made a cart before build season this year. It is an extruded aluminum frame, covered with aluminum plate. The sides of the shelves are black powder coated aluminum with our logo cut out by waterjet. The shelves hold tools, batteries, and our charger. The handles are chrome bmx pegs and the wheels are jumbo casters that we salvaged from some huge steel trolleys donated to us by General Motors. The robot is held off of it's wheels by four pieces of extruded aluminum.
