Go to Post I love how these contests always seem to find their way to go back to Dave Lavery and (pick one) Krispy Kreme/Heidi/Photoshop - DCA Fan [more]
Unread 07-04-2012, 22:37
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Tube Versus Channel
As a relatively new member to the FRC community (this is my second year in the competition) I have been very closely looking at other teams' robots, as seeing how different teams design is rather interesting to me. While doing this, both online and at regional competitions, I have noticed several things about frames, which have gotten me thinking about robot design in the future, as my team is likely to design some sort of showbot over the summer for outreach, as well as participating in future FRC seasons.
The main thing that I have been wondering about is structural materials. Namely, I've noticed several distinct types:
a) Channel
b) Tube
c) 80/20 or other extrusions
Noticing these differences lead me to wonder:
Why do teams choose these different materials?
I have several theories on the benefits of each.
For channel, it may be for convenience, as, if I remember correctly, 1" channel is the typical kitbot construction. Additionally, this isn't an all together structurally unsound material. This also may be perceived as cutting weight. It also only requires one hole to be drilled through the material to bolt something to it.
For tube, some possible reasons may be that it is more structurally robust than channel. Also, there is more area to mount onto, which may be a benefit.
For 80/20, possible reasons may be the ease of prototyping with this material, as well as the excellent structural integrity it affords.
I am interested as to why different teams choose these building materials, as well as what benefits and disadvantages are seen in them. If any other team members could offer some advice to this humble sophomore, I would be much appreciative.
If anyone has already posted a thread to this effect (I didn't see one when I searched, but I may have missed it), I would also be perfectly grateful with a link to that thread.
Also, this is specifically for metal robots. I am aware that some teams make wooden or plastic robots, but as these are rather uncommon, I would appreciate it if any discussion focused on materials for metal robots.
Unread 07-04-2012, 23:52
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Tube Versus Channel
I think your hands down favorite/best material to construct a robot out of is waterjetted and bent aluminum sheet metal, since you can design it to the exact requirements you need, given you an optimum strength to weight ratio.
Lacking the fabrication support necessary for the above, 57 has settled on the kit frame with a chassis of 1"x1"x1/16" wall square aluminum tube, mostly held together with more 1/16" sheet plates riveted with 3/16" aluminum structural rivets. It's pretty lightweight, plenty strong if you're not dropping your robot off a cliff, and we can get 20' sticks of the stuff for $6$20 from a local supplier, even on a Saturday. Which is harder to say about AM channel or 80/20 or another T-slot extruded aluminum.
Thick wall AM style channel is heavier and tougher than we need for any framing purposes. Thin wall channel would be flimsier than tube, if lighter. Either of the u-channel options means you have an entire side that can be a pain to attach things to.
80/20 style extruded aluminum is good for prototyping and quickly adjusting parts, etc. Only problem is that it's heavier than the 1/16" wall tubing that we use, for no more benefit than the quick propotyping.
Unread 08-04-2012, 00:06
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Our frame is all aluminum tubing welded together. 1x1 1/16 wall for most of the upper structure, 1x2 1/16 wall for the base. As well as 1x2 1/8 wall for the base side beams that have the DTs mounted.
We do all of the welding in house and find that a welded tube frame is light and very stiff if done correctly.
It also gives us flexibility of the frame geometry and how we mount other components.
Unread 08-04-2012, 00:07
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by Kevin Sevcik View Post
Lacking the fabrication support necessary for the above, 57 has settled on the kit frame with a chassis of 1"x1"x1/16" wall square aluminum tube, mostly held together with more 1/16" sheet plates riveted with 3/16" aluminum structural rivets. It's pretty lightweight, plenty strong if you're not dropping your robot off a cliff, and we can get 20' sticks of the stuff for $6 from a local supplier, even on a Saturday. Which is harder to say about AM channel or 80/20 or another T-slot extruded aluminum.
Interesting... We use 1/8" wall square tube on a kitbot frame, and every year it seems like we bend or break at least one piece of it tubing -- making us leery of going any thinner. (Also, there's no such thing as a "local supplier" in Naples, NY... Unless you need a cow, STAT.)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 08-04-2012, 00:23
We used to go with all 1/8" wall as well. We eventually tired of being constantly overweight with frames that took up a distressingly large percentage of our weight allowance. Yes, they would probably fare well in a head-on collision with a small motorcycle, but that's obviously a bit overdesigned for most FRC games. Our biggest problem was that we usually ended up using the 1/8" in various locations for motor mounting bars, etc. Places that didn't need anything near as strong as 1/8".
So, we build of the kit frame, and figure on that taking any big impact loads. Anywhere we're not expecting to get hit gets the 1/16", and we look at using 1/8" if we're likely to be hit hard and often somewhere.
Although, this reminds me of the single biggest problem of using 1/16" wall tubing. If you're mounting something by bolting through the tubing, you need to be cautious about over-tightening your bolt, or you'll squish and deform your tube distressingly easily. We're constantly reining in the gorillas on the team that have a bad habit of severely over-tightening bolts and such.
Unread 08-04-2012, 00:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's another fun problem with using tube, you need to plan your attaching points pretty early on. Welding (or riveting) a mounting tab to the tube is a good way to go.
We built a welded steel frame using mostly thinwall square tube and some angle and strap for this year's robot...no problems at all with the frame.
Unread 08-04-2012, 00:52
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
You can either drill a large hole on one side of the tube so that you're only bolting through 1 face, you can use large washers, be careful with your tightening, some teams have had success with rivnuts, or you could try to find some other way to mount to the tube entirely (instead of bolting).
Unread 08-04-2012, 01:11
(Last thread derailing, I swear)
Rivnuts are definitely cool and we've used them before. Did I mention we have gorillas on our team? Last year they cross threaded a bumper attachment screw in a rivnut, then spun the rivnut. We missed a match getting that bumper off and replacing that rivnut. So we're running reversible bumpers now and are a little more cautious of rivnuts.
Unread 08-04-2012, 01:38
DampRobot's Avatar
Physics Major
AKA: Roger Romani
It appears like most teams use welded aluminum extrusion, if not using the kitbot frame. The most common sizes appear to be 2x1x1/8 on the base, and 1x1x1/16 on the superstructure.
My team has took the rather unusual step of using rivets last year to assemble the frame. We used almost exclusively 1/16" aluminium tubing, with 1/8" gusset plates that riveted the whole thing together. A variety of sizes of rivets were used, from 1/8" aluminium to the huge 1/4" steel. The rivets were a weight saving measure after trying to use steel bolts.
I would recommend rivets to a team with an accurate mill and a desire to save weight. With an accurate mill, the gussets and the frame members can be made so the frame is perfectly straight (we have had some problems with crooked welded frames in the past). Also, rivets allowed us to use almost exclusively 1/16" tubing, which saves weight, but is near impossible to weld. I estimated that this saved us 5-8lbs.
If you do decide to rivet (or to bolt and then are forced to go to rivets), keep in mind that you have to size the rivet for how much material it is gripping. Not just any size will do. Also, 3/16" rivets work in #10 holes.
-Plutarch
Unread 08-04-2012, 01:41
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Although they aren't very well known, rivnuts can make for a very neat solution in my experience. When I went around asking for rivnuts at SVR, people looked at me like I was crazy. I'm glad to hear someone has heard of them.
-Plutarch
Unread 08-04-2012, 03:48
FRC #1836 (MilkenKnights)
We also like aluminum tube. Really, the best thing to use is 1 x 2 aluminum tube, welded. 1/8 in thick for drive base, and basically 1/16 for everything else. If used correctly it is perfect. Minimize the amount of frame material you need. Look at any 254 robot, and you will see how simple the frame actually is. It makes for lighter robots, and you really don't need anything more. Also, 1/4 in, waterjetted, aluminum plate goes very nicely with this. It makes building 20 times easier, and reduces the amount of tubing you need. Plus, you can make custom gearboxes. Really, it pays off to get a 2D sponsor, as they can turnaround parts amazingly quickly.
On the subject of sheetmetal, while a lot of good teams use it, there are plenty of good robots built out of tube, as long as you streamline the design process(254 again comes to mind). The nice thing is that the robot comes together lighter, more quickly, and more accurately than an aluminum tube robot. On the other hand, you need to have a good team of CADders, and have the sponsor to be able to do it.
Unread 08-04-2012, 05:26
Gray Adams's Avatar
2 questions.
1) Is your 1/4" plate .25", or is it like ours and ranges from .22" to .24"? That made our gearboxes this year a little difficult to get fitting correctly (if you've seen the gearboxes, you know what I mean)
2) Besides custom gearboxes, how else do you use it in your frame? We have a lot more frame right now than I'd like, but I can't see how 1/4" plate would make it significantly better.
Unread 08-04-2012, 11:53
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If your 1/4 plate is .22 to .24, you ordered a gauge thickness rather than 1/4 plate.
1/8x1 tube is virtually the same weight as 1" 80/20.
This year we used a lot of 1/8x1 angle. Half the weight of the equivalent channel & allows bolts to be properly torqued without crushing the section.
We use mostly 1/4-20 bolts. A little heavier than other options, but you don't have to worry about the inexperienced over torquing them. Carroll Smith has a great book about fasteners "Nuts, Bolts, Fasteners and Plumbing Handbook"
It is all about the details & trade offs.
Unread 08-04-2012, 15:25
qzrrbz qzrrbz is offline
FRC #0469
qzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to behold
Another semi-endorsement for rivnuts. They are really cool things, in theory. However, beware of using in 1/16th wall stock -- very easy to spin them, and then you have a mess. Installation is also an art! Too much force, thinking to make a better seat, tends to mess up the threads, especially in aforementioned 1/16th wall. Still, they're pretty neat and tidy when done well!
Unread 08-04-2012, 15:40
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
1 question that I have that I have not seen mentioned is price. What is the cost of the tube versus the kit bot c-channel, which is included with the KOP. If it is expensive, I don't see much bonos to it over C-Channel, which works fine for most uses (at least for 3397). We used it on our chassis and tower and electronics mount. It is light and pretty durable. So, unless it has a VERY good benefit, I do not see the point of buying the tube.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
