Go to Post Good thing that this is FIRST and not FIRD (For inspiration & Recognition of Dancing) ... :) - Jason Morrella [more]
Unread 08-04-2012, 17:20
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
Loop Timing on Robot Drive
We have been doing some experimenting with an issue we have put off for a while. We read our joysticks in teleop and then set global variables. We actuate the motors, including drive in periodic.
This works well and our robots drives just fine. However when we set our loop time to 100ms, setting our Drive vi, we get the following error/message at the diagnostic tab of the driver's console.
Robot drive is running too fast or being starved due to too much code.
When we set that loop for 10ms, no diagnostics error/message.
The performance of the robot does not change. The setting of the drive is the only action in the loop. This error does not seem to hurt us, but I have wondered for a while why we get it and was hoping for some help from the community.
http://www.team1912.com
2013, 2012, 2011, 2010 Regional Chairman's Award, Bayou Regional
2013 Woodie Flower's Award, Bayou Regional
2012 Dean's List Winner (Rachel Holladay)
2015, 2014, 2013, 2012, 2011, 2010 Beta Test Labview/Hardware
2012, 2011 Best Website, Bayou Regional
2011, 2009, 2006 Gracious Professionalism
2007 Bayou Regional Winner
Unread 08-04-2012, 17:36
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Loop Timing on Robot Drive
The error you're experiencing ("the loop that contains RobotDrive is not running fast enough...") occurs when the default safety timers within the drive code trip. Whenever the drive motors go >100ms without an update, the motors will be disabled. This prevents things like runaway robots.
When you set the wait on your loops to be 100ms, you're cutting this threshold very close. The Wait VI is not extremely precise (it's good enough for our purposes but there are ways to do it with more accuracy), and it's possible that your loop times could differ by a little bit, thus tripping the safety.
If you reduce the wait on your loop (~20ms is usually pretty good - that's the speed at which new packets are received by the robot), you should eliminate this problem. Times greater than 20ms often occur some control lag, since new data is being sent faster than the robot can process it, and you want your loops throttled somewhat to be nice to the CPU. 20ms is a pretty good number for this.
Unread 09-04-2012, 21:35
rachelholladay's Avatar
rachelholladay rachelholladay is offline
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Alright, thank you very much! We changed it to wait to 20 milliseconds and that fixed the problem. Its alwasy nice to know why solution works, so thanks for explaining.
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
