Go to Post I think this post is a lot of words saying "My name is Billfred and I approve MiniBots 2017" - Andrew Schreiber [more]
Unread 09-04-2012, 01:15
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
Re: Tube Versus Channel
If you have a local aluminum supplier, just tell them that you'd like to purchase any 1"x2"x1/8" or 1/16" wall aluminum that they have as scrap. You can cut your costs from about $3.25 per foot to $.40 per foot. Work it year round and you'll have plenty of material come build season.
Scott McLean
FIRST Team 3512, the Spartatroniks
Team role: mentor
2011: Highest Rookie Seed and Rookie Inspiration Award Long Beach Competition
2012: Winner Los Angeles Regional -- w/ Team 987 and Team 1717
2013: Finalist Los Angeles Regional -- w/ Team 599 and Team 981; Engineering Excellence
2015: Entrepreneurship Award - Ventura Regional
Unread 09-04-2012, 04:15
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
We used 3*1.5 inch tubing with .125 thick walls and a special hole pattern cut into it this year. 3/16 rivets and grade A 10-32 Button-heads are our fasteners of choice. This year the drive frame weighed 10lbs, and the entire frame weighed less than 16lbs. If you have the machining resources to do it, I would look at perforated tubes as a construction method, I cannot think of a way to make a lighter frame. For some examples check out team 40 or 111's robot from 2011
