Re: Kinect with Labview
No, but it may be that you haven't installed the same SW as what was installed on the small laptop.
In other words, run through the Kinect checklist, see if the MS examples work, etc. Greg McKaskle |
Yes, i have went through list, an all the examples work
If the examples work and the SW is versioned beta 2, then the Kinect Server should work. If needed, it can be launched in a debug mode that will leave its window open and give more info if there is an issue. If the server is working, then everything else is just shoving the info around and displaying it.
If you have more information about where it fails, please provide it. Greg McKaskle |
So, you're getting an error message about the Kinect Server?
There is a button on the Operations Tab that will restart it. In addition to knowing what the error message says, there are a couple of places to look for Kinect status that would be helpful to know:
If the Kinect Server is failing, then you can run it in debug mode and get more information. It's located on your PC under C://Program Files/FRC Kinect Server/KinectServer Debug Mode Last edited by Mark McLeod : 13-04-2012 at 18:23. |
