#8
Re: Overlaying rectangles over the targets in the camera feed
My attachment showed the disabled code for unflattening the high priority data, and the wire with the low priority too. If you are using the high priority data, check to see what is in the string and check the type you are unflattening it with. You may even find it useful to go back to a simpler type in the C++ and LV dashboard, and get that working, then add elements a few at a time to learn which is failing.
Greg McKaskle |
