Go to Post School cannot teach everything you need to know so they teach you how to learn. - kstl99 [more]
Unread 10-04-2012, 09:26
Nirnaeth Nirnaeth is offline
Coach/Mentor
AKA: Michael Liang
FRC #6367 (The Brooke High ElectroLights)
Nirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud of
Anyone use aluminum bolts?
We had some significant weight issues this year with our robot, and we realized the bulk of our weight was hardware-related. We had standardized with 1/4"-20 socket cap bolts, but are thinking of switching to either:
1. 10-32 bolts
2. Aluminum 1/4"-20 bolts
I'm worried the aluminum bolts will not be as durable, but they are 1/3 the weight of steel bolts. Thoughts?
Unread 10-04-2012, 09:32
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Anyone use aluminum bolts?
Step down to 10-32 bolts, 1/4-20 is overkill for most FRC applications. Look up some of 973's work, they use a bolt pattern that allows for use of either a 10-32 Bolt or a 3/16" Rivet. Not a bad way to save weight.
I'd recommend staying away from Aluminum Bolts whenever possible. I've seen a few over-eager students give them a turn too many with a wrench and snap the heads right off.
-Dustin Benedict
Unread 10-04-2012, 09:38
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
We have used them in the past, but yes only put the in the hands of people that are unlikely to over-torque and sheer them. Our current stock is often used to replace at steel fastener that was used previously and swapping to a rivet isn't practical.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 10-04-2012, 09:46
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The one real nice thing about stainless steel bolts, is the need to never replace them (in a properly designed usage). Aluminum simply isn't as durable, and as already said, it's pretty easy for a student to over tighten and pop the head off. All of our bolts are stainless steel.
That said, the key to any good design is using the right part in the right application. Some things on a robot (like the frame that provides the structure for the entire robot and takes the brunt of the impacts) should be done with 14/20's. Others can be done with 10-32's. Still other applications can use smaller sizes.
We have a standardized set of bolts for use with our robot, everything from 1/4-20's to 4-40's. by using a constant thread count for each size, we can match up bolts or taps very easy - there are no 10-24's in our shop, so we have no 10-24 nuts and no 10-24 taps. All we have is the equipment for 10-32's.
We also use pop rivets for a lot of applications. By a lot, I mean most applications that aren't structural. A couple of pop rivets can, in the correct application, easily replace a heavier bolt.
Unread 10-04-2012, 10:10
Nate Laverdure's Avatar
FRC #2363
Do you use stainless nuts also? If so, what do you do to avoid galling?
Unread 10-04-2012, 10:13
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Aren't the KOP frame bolts aluminum? They seem to be much lighter than a hex head counterpart. We use them extensively without issue.
GitHub
Unread 10-04-2012, 10:16
thefro526's Avatar
Mentor for Hire.
According to AM they're just Zinc Plated Steel: http://www.andymark.com/product-p/am-1206.htm
Maybe it's because they're SHCS?
-Dustin Benedict
Unread 10-04-2012, 10:19
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Welds don't weigh much. Rivets don't weigh much. Smaller screws (10-32) don't weigh much.
I'd be concerned about how fragile aluminum bolts are...
If you can replace a steel fastener with an aluminum one, then the steel fastener is too big for the job. Just use a smaller fastener, or reconsider your design to eliminate the need for so many fasteners.
Unread 10-04-2012, 10:21
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
You can use rivets without any problems for structural applications; the key to success is to design the structure in a way that both uses many rivets to spread the load out and has the rivet locations in areas where they will primarily see compression or shear loads (tensile loads will pull the rivet out).
If there are expected tensile loads, this too can be overcome by the use of a bracket that rivets in two planes 90 degrees apart so that one is always the shear load joint.
Once you use rivets (especially with a pneumatic riveter), you'll never want to use bolts again.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-04-2012, 10:51
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I'll second that rivets can and should be used structurally to save weight. We have used them with no problems. If you really need a bolt, I would recommend a 10-32 over an aluminium bolt.
Keep in mind, all these fasteners can be appropriate, just in different situations.
-Plutarch
Unread 10-04-2012, 11:03
Brandon Holley's Avatar
Truer words have never been spoken.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 10-04-2012, 11:22
qzrrbz qzrrbz is offline
FRC #0469
qzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to behold
-Brando
Amen! But, you still have to be able to get on the rivets squarely -- that doesn't change. But, boy, does it make driving those 3/16th guys a lot less painful!
We have used aluminum bolts to replace steel in the past. The lazy susan turret we had in 2009 and this year both had holes designed for 1/4-20 iirc, so there we used AL.
Unread 10-04-2012, 11:33
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Off topic: I'd personally use 10-24 bolts over 10-32. coarser threads in my experience are stronger (the weight difference is negligible).
I agree that rivets rock... just keep in mind that if you ever need to remove/replace the part, you will have to drill out the rivets and rivet it again. In this application, I suggest NC (national Coarse) bolts and locknuts...
Unread 10-04-2012, 11:40
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
+1 to rivets.
We have used aluminum nuts a few times when a large bolt was used in shear.
No complaints so far.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 10-04-2012, 12:04
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Also of note: aluminum 1/4-20 screws cost about five times as much as steel 10-32 screws.
