Go to Post That is just ridonkulous. - Brandon Holley [more]
Unread 05-01-2003, 22:05
D. Gregory's Avatar
D. Gregory D. Gregory is offline
FIRST Junkie
no team (UHS Wolfpack)
D. Gregory is an unknown quantity at this point
Send a message via ICQ to D. Gregory Send a message via MSN to D. Gregory
Motor rpm and Torque
What is the rpm and torque for all of this year's motors. Thank you.
Duct tape is the force that holds the universe together. Everywhere except FIRST that is.
Unread 05-01-2003, 22:18
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
You need to download and read "The Robot.pdf" off of the FRC Documents page. It isn't as good as last year, but the basic information is still there, under "Kit of Parts".
Unread 05-01-2003, 22:35
Generator of Entropy
FRC #2973 (The Mad Rockers)
I see it for the new Bosch and for the Fisher Price, but the others don't have any technical data.
Does anyone have the URL's for last year's appendix with the specs on the www2.usfirst.org site? they took the links off the main site. This has the specs for the other motors. I have a copy of the file at work but not at home. Now that i have broadband I'll download it here.
Unread 05-01-2003, 23:15
OK, I found a hard copy from 2000 - The motors don't look quite the same but similar enough. Since I haven't seen anybody else posting specs, here's what I've got and it will at least get you started until we see the right ones:
Window Motor (ITT Automotive): 20 Amps Stall Current, 6 Nm @ 41 RPM, 1.8 N.M @ 64 RPM
Van Door Motor (Tiagene): 75 RPM No Load Speed, Stall Torque 37 Nm Clockwise, 34 Nm Counter-Clockwise, Stall Current 40 Amps.
Globe Motor (with Drive Assembly), at 10 Vdc: No Load Speed 87 RPM, Stall Torque 150 In-Lb, Stall current 18.5 Amps, No Load Current .82 Amps.
Globe Motor (Motor Only), at 10 Vdc: No Load Speed 97RPM, Stall Torque 30 Oz-In, Stall current 18.5 Amps, No Load Current .82 Amps.
Unread 06-01-2003, 01:03
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Gary,
If you still need anything from last year, I just got done archiving it here: http://www.cvhsrobotics.org/resources.htm. You'll find the 2002 documentation toward the bottom of the page.
-Kevin
Kevin Watson
http://kevin.org
Unread 06-01-2003, 01:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
For motor specs from last year's motors and the van door motor, they may be found at www.team696.org/motorspecs.html There is also a link to download the Joe Johnson motor comparison spreadsheet.
Unread 06-01-2003, 01:18
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
PLEASE NOTE:
the drill motors ARE different this year - do not do calculations using the drill motors on these specs...
Tom
Unread 06-01-2003, 08:18
Thanks for the links. Still, the motors look different than last year's, and the manufacturers are listed as different (Nippon-Denso vs Valco for the window and Bosch vs Taigene for the Van door), so as soon as someone gets the official specs please post. These should be adequate for now.
Unread 06-01-2003, 10:14
JTH JTH is offline
#1447 (Panther Robotics)
JTH is an unknown quantity at this point
Send a message via AIM to JTH
Did anyone else notice a discrepency in the information on the new Bosch with gearbox?
On page 5, the robot manual describes the output of the bosch with gear box as 0-450 or 0-1500, but if you take the 19670 no load RPM with the ratios of 12.07:1 or 42.62:1, you get (approximiately) 461.5 or 1630 RPM.
Unread 06-01-2003, 10:36
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Efficiencies
I believe their numbers, but that means that the efficiencies for these gearboxes are pretty darn good.
After doing some calculations, I get these efficiencies:
Gearbox in High: 92%
Gearbox in Low: 97.5%
The "old" gearboxes had these efficiencies:
Old Gearbox in High: 80%
Old Gearbox in Low: 70%
... so...
With a larger motor, more efficient gearboxes, and a bigger circuit breakers (40A compared to 30A), these drill motors may be close to double the power compared to last year's Bosch motor/gearbox combination. Holy torque, Batman!
Andy B.
Unread 07-01-2003, 20:32
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
This is important... to choose the right motors for the right jobs, and to figure out gearings and such we need to know motor specs. Preferably stall torque, free RPM, torque vs RPM curve.
Specifically the new drill motors vs "chalupa" (if thats how you spell it). Which has more torque, what are they RPM's? Which is better to use for drive train, what are the RPM-torque curves?
ACK
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 07-01-2003, 21:36
President, VEX Robotics, Inc.
Drill vs. Chiaphua
The Chiaphua is the same motor as last year with a different shaft. It was made specifically for FIRST and is the same model number with an "FR" in front of it. See the link below for the Chiaphua spreadsheet, but disregard the pinion information.
The new drill motor has more power than the Chiaphua (see some specs below), but both are very good candidates for a drive motor.
Bosch drill motor specs (@12V):
Stall Torque = 0.87 N-m
Stall Amps = 127
Free Speed = 19670 RPM
THe above is preliminary info, but I should be getting confirmation from Bosch tomorrow.
-Paul
Unread 08-01-2003, 17:02
If this is correct, the drill motors are still less powerful then the atwood "chaiupas" (i will never spell that correctly)? By my conversions, the chaiupas stall at about twice the torque as the new drill motors (though both at 100+ amps, ACK!).
Someone check me, stupid english/metric.
Greg
Unread 08-01-2003, 17:26
Power, not torque
The Drill motors have much more power: .87 N*M/2 * 19670RPM/2 *2*PI/60 = 450 Watts
Chiaphua power = 500RPM/2 *2.2 N*m/2*2*PI/60 = 317 Watts
Hope this clears it up. In other words, if you gear the drill to the same output free speed of the Chiaphua, the drill will have more torque.
-Paul
Unread 08-01-2003, 22:09
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
but the chiaphua is bigger! that means it MUST be better?!
heh, go small but powerful. If only we could replace out chiaphuas with more bosch drill motors.
Anyone want to trade (just kidding, i read the rules)
Robot output torque Alex1072 Technical Discussion 9 12-03-2003 22:13
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
Traction Limited, rather than torque Simon G Technical Discussion 6 23-01-2002 07:08
