Go to Post Because, y'know, FIRST can't make it easy for us. - WinterPoet [more]
Unread 09-04-2012, 14:32
Redstone's Avatar
Redstone Redstone is offline
Me gusta java
AKA: Ben Beals
FRC #4043 (Nerd Herd)
Redstone is an unknown quantity at this point
Exclamation Robot Tethering Issues
This past weekend we went to the las vegas regional and had no problem connecting the robot the the feild management system. Whenever I try to tether the classmate to the Crio it doesn't find a connection. At first we thought it was a bad cable but after trying two other cables it still didn't work. Any ideas on what the issue could be?
nerdherd4043.com
2012 Oregon Autodesk Regional Rookie Inspiration Winners
2012 Las Vegas Regional Rookie All Star Winners
Unread 09-04-2012, 14:36
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Robot Tethering Issues
You need to use a crossover cable when going directly from the Classmate to the cRIO. I believe they were all yellow in this year's KOP.
Why not just connect the Classmate to the Dlink?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 09-04-2012, 14:39
Redstone's Avatar
Me gusta java
AKA: Ben Beals
We also tried connected it to the dlink and we still didn't get a connection. This is a weird issue because we didn't have this problem during our first regional.
nerdherd4043.com
Unread 09-04-2012, 15:12
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Sounds like an issue with your IP. Go here and follow "How to configure your C-RIO", that should fix it. Also ensure that your driver station software and utilities are up-to-date.
Unread 09-04-2012, 15:52
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
I had this issue early in the season on a non-classmate computer. It turns out that the Ethernet port was disabled on the computer. Ensure that the port is, in fact, enabled.
Dom
Unread 10-04-2012, 06:32
If you are running the driver station, it has a Diagnostics page to help determine what is failing. The second column of LEDs starts with the equivalent of a link light. If off, it indicates that a cable is missing/bad, or the NIC is disabled. If it is good, the next light moves one step closer to the robot, and another, etc. The first LED is the result of an ipconfig, and the others are just pings of the expected IP addresses.
You also shouldn't need a crossover cable unless neither device implements auto-sense. Almost all laptops still running will. If they implement gig-E, it is almost guaranteed. The cRIO and camera do not, and that is the connections that requires a crossover cable.
Greg McKaskle
Unread 10-04-2012, 12:16
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
We found that windows gets confused on which LAN port to use. If you are tethered, make sure you enable the wired LAN and turn off the wireless LAN.
the driver station will then activate the correct port. (sometimes)
You may still need to manually adjust the IP address if the wireless claimed the default earlier. Windows seems to remember that old IP assignment even when the port is disabled.
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 10-04-2012, 15:12
mdrouillard mdrouillard is offline
FRC #0772
mdrouillard is an unknown quantity at this point
Not likely the issue you were having , but during build season we actually had 1 bad port on our dlink. Port 2 was simply bad. So, Crio in port 1, camera into port 3, and laptop tethered on port 4 when needed. So, if none of the ideas above work, check either the port that the crio is connected, or your laptop on the dlink and make sure you have a link light on the dlink.
Keep in mind a link light only tells you that that device sees the other device. it does NOT tell you that the other device sees you. To make sure you have bi-directional communication, you need TWO link lights, one on each device facing every other connected device.
md
Unread 11-04-2012, 08:54
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Don't forget that if you are trying to connect via wireless your bridge password needs to be reset and also check the switch on the back is set to access point mode when not at competition.
The manual here, page 29 explains it.
Unread 11-04-2012, 09:52
Redstone's Avatar
Me gusta java
AKA: Ben Beals
Unhappy Re: Robot Tethering Issues
I forgot to mention that I can't do anything about this until the championship because the robot is still in it's Bag
nerdherd4043.com
Unread 11-04-2012, 11:37
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
At CMP, try this as soon as you can. If you can't get it working, look for a volunteer in a orange ball cap. That is the Control Systems Advisor. The CSA is tasked with helping any team that needs it.
