Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 04-10-2012, 07:55 PM
Team3881 Team3881 is offline
FRC #3881
Team3881 is an unknown quantity at this point
Cannot make a static reference to the non-static method
Or, more specifically, "Cannot make a static reference to the non-static method getImage() from the type AxisCamera."
The code is just
ColorImage image = AxisCamera.getImage();
But eclipse just gives that error.
I am sure I'm missing something simple, and/or something huge. Help would be appreciated.
Unread 04-10-2012, 08:01 PM
Jared Russell's Avatar
Taking a year (mostly) off
Re: Cannot make a static reference to the non-static method
You need to get an instance of an AxisCamera before you can call that method.
Example:
// Typically you only want to do this ONCE; camera should be a class member
AxisCamera camera = AxisCamera.getInstance();
// Then you can get the image as often as you would like (but it's pretty slow, you don't want to call this more than once per 50 milliseconds or so!
ColorImage image = camera.getImage();
