Go to Post ...next years game will hopefully make my head hurt, this years did. - Michael Leicht [more]
Unread 31-03-2012, 19:04
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
AXIS Camera Overlay feature.
Hello all,
We have the Axis camera on our shooter to help with aiming and would like to put a vertical line though the middle of the image.
We tried to used the built in Axis feature to do this
http://www.axis.com/files/manuals/um...38_en_1101.pdf [Page 19]
that lets us upload an image, however does anyone know what format the image has to be?
We tried gif, jpeg, bmp, png with fail to upload errors. The files were about 7kb.
Thanks
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 31-03-2012, 20:54
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Re: AXIS Camera Overlay feature.
Our team doesn't have the new camera, so I can't determine if what you ask is possible camera side...But if you are open to using Labview, you can modify the dashboard project (the window with the camera feed) to display the crosshairs.
This post provides instructions on how to do so.
http://www.chiefdelphi.com/forums/sh...09&postcount=4
It is from this thread, which can give you some more ideas/help.
http://www.chiefdelphi.com/forums/sh...abview+overlay
Best of Luck!
Unread 02-04-2012, 13:42
Mk.32's Avatar
AKA: Mark
We are currently using the SmartDash so I might look into modding that.
But I am curious to see if I can do this directly on the camera it self.
Unread 02-04-2012, 14:44
Jay Meldrum's Avatar
Jay Meldrum Jay Meldrum is offline
FRC #0067 (H.O.T.)
Jay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud of
Originally Posted by Mk.32 View Post
Hello all,
Thanks
Just to make sure, is the file you are uploading the same resolution that your camera is set to? i.e. 320 x 240 camera res gets a 320 x 240 picture?
2012-2015 - FRC 67 - Programming/Controls Lead Mentor
2003-2005 - FRC 857 - Driver
Check us out at http://www.hotteam67.org
Previous year design docs, programming tutorials, and more!
Unread 02-04-2012, 14:48
Mk.32's Avatar
AKA: Mark
Yes, I tired an 640x480 [resolution we were using] as well as a 320x240. I also tried uploading just the icon I wanted which was an 10x480 image.
Unread 02-04-2012, 14:59
FRC #0067 (H.O.T.)
Hrmm... I'll have to see what we did a while back when we were playing with that.
I know the privacy mask feature works. You could put a red rectangle straight down the center of your image.
Unread 02-04-2012, 15:59
Mk.32's Avatar
AKA: Mark
Thanks for the suggestions!, I will look into the privacy mask it seems to be able to do what we need.
Unread 02-04-2012, 18:04
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
We did this just fine.
We used a BMP image.
Try uploading the wrong file type, it will tell you what type it needs to be.
Unread 02-04-2012, 22:51
Mk.32's Avatar
AKA: Mark
What resolution did you upload and how big was the image?
Unread 11-04-2012, 08:40
FRC #0067 (H.O.T.)
Not sure if you figured it out, but I just played with this last night.
You need to make sure your image is the same resolution that your camera is set to and save the image as a 24 bit BMP. I used GIMP 2 to do this (freeware photo editor, similar to photoshop). Paint might work?
In my case, I just made a picture with a white background. Type in "FFFFFF" when asked for the transparency color.
There is also a setting on one of the menus in the camera to enable the overlay for streaming, make sure you check this as well.
