Go to Post Gracious Professionalism does not take a holiday. - JaneYoung [more]
Unread 11-04-2012, 11:53
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Drills
How do you keep drivers interested while developing their skills?
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 11-04-2012, 12:00
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Drills
Competition and a goal to work towards.
We do a number of driving drills, including a bridge balancing drill, to see who gets the fastest time. Usually a couple of coaches try it first so that they can give good advice and so that we set a fast time for the drill (myself and another coach drove when we were students, so we're pretty good).
Our chassis driver started off doing a bridge-balancing drill in about 30s, then got it down to 11s, beating the best coach-driven time of 13s.
Unread 11-04-2012, 12:01
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Drills
In the rare cases the robot is all in one piece before ship (and not getting upgraded after being in one piece for 5 minutes), we usually set up a mini obstacle course.
Something like:
-Drive here, acquire the ball
-Drive around this marker, then shoot the ball
-Then do the same thing backwards
-Then park the robot in a challenging spot
It has a well-defined beginning and end, and so you can time it and make a mini-competition, which keeps people interested.
Unread 11-04-2012, 12:20
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Drills
Our main drills this year were
#1 8 balls available (4 on the two bridges) how many points could be scored in a timed match. The high score was 62
#2 8 balls available, the six not on the robot were on the other side of the barrier, how many points could be scored in a timed match. The high score was 52
#3 6 balls available 4 were under a bridge or in a corner. I don't recall the high score on that one.
Unread 11-04-2012, 12:48
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Drills
If I were you, I'd try new drivers. Ones who are naturally interested in developing their skills.
This message is hidden because Jack Jones is on your ignore list.
Unread 11-04-2012, 13:08
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Founder, 469 Mentor
FRC #0469
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
Re: Drills
We cycle which auton we start with and then have 2 balls available on co-op bridge and 2 on the alliance bridge, the other 3 are with our inbounder. total of 9 balls.
we run an all offensive drill balancing at the last 15s (gather shoot)
we run an assistance drill lowering the alliance bridge at a predetermined time for 10s and then continuing to score and coming back to push our 2011 robot carcass up on the alliance bridge for the double at 20s
we ran defense drills of putting robot carcasses and cones all over the defensive zone pick up balls clear them to offensive zone don't touch anything other than the field elements then balance at 15s
mentors will also randomly get in the way pushing old robots in the way, kicking the bumpers at the fender, we also fain failures(you can't adjust the shooter angle for the rest of the match or the turret cannot be adjusted the rest of the match)
this has done wonders for our drive team:
we put up avg6 in auton and 8 points teleop at week 0, 20-30sec to balance
now we avg10 in auton and 18 points teleop at week 6
our driver now typically balances 5-10 sec (initial contact with bridge or robot carcass)
try to switch it up allot and if its an issue getting your drivers to show up...get new drivers
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 11-04-2012, 21:52
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: Drills
I was robbed, I tell you. I still own the figure eight, at least.
