Go to Post "It's not child labor if they wear a team shirt!" - Vermeulen [more]
Unread 04-11-2012, 06:50 PM
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
AS5030-AB-2.0
How do you program a AS5030-AB-2.0 magnetic rotary encoder? what class do you use?
in FIRST, it's process over product, and team over robot.
http://www.roguerobotsof4h.com/
Team 3585 Rogue Robots of 4-H
Unread 04-11-2012, 07:08 PM
Re: AS5030-AB-2.0
May I ask: What are you using it for?
Unread 04-11-2012, 07:32 PM
Re: AS5030-AB-2.0
speed sensor
Unread 04-11-2012, 07:53 PM
Re: AS5030-AB-2.0
speed sensor
You don't want to use the AS5030 absolute position encoder as a speed sensor, unless the speed you are trying to measure (in rev/sec) is less than half the code execution frequency in Hz... which it won't be for a shooter wheel.
There are threads in CD discussing this.
