Go to Post theyre not planning on blowing up the comet... just running straight into it and seeing what happens. :D - Winged Wonder [more]
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Unread 02-04-2012, 15:09
Ro13star Ro13star is offline
FRC #0832
Ro13star is an unknown quantity at this point
Encoder for Rpm help!
Hi, i am a new programmer for my team and i am having problems with using the data from the encoder in the program. i have confirmed the encoder works with a multi-meter. the encoder is a us Digital e4p.
this is the relevant part of my code please help:
class RobotOscar : public IterativeRobot
// RobotDrive myRobotDrive; // robot drive system
Jaguar shooter_motor;
Jaguar shooter_motor2;
Encoder left_shooter;
double count;
public:
RobotOscar(void):
shooter_motor(3),
shooter_motor2(4),
left_shooter (3,4,false)
void TeleopInit(void) {
printf("Telop Init Entry\n");
left_shooter.Start();
left_shooter.Reset();
void TeleopContinuous(void)
while(IsEnabled() && IsOperatorControl()){
count=left_shooter.Get();
printf("count= %f \n", count);
also can you use one pwm to a digital imput to get just the A channel from the encoder for rpm only. << is the current set up
Unread 02-04-2012, 15:14
Re: Encoder for Rpm help!
How did you confirm that the E4P encoder works by using a multi-meter?
Unread 02-04-2012, 15:17
The E4P encoder output is not PWM.
You can use just one channel, but then you would need to use the Counter class, not the Encoder class, to process the signal.
Unread 02-04-2012, 15:26
Jay Meldrum's Avatar
Jay Meldrum Jay Meldrum is offline
FRC #0067 (H.O.T.)
Jay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud of
If you are using a digital I/O/PWM encoder here is an example of code.
(Note: we use pointers)
class BuiltinDefaultCode : public IterativeRobot
        //Declare Encoders
        Encoder *m_Encoder1;
public:
        BuiltinDefaultCode(void)
                //Initialize encoders
                m_Encoder1 = new Encoder(1, 2, true);
                m_Encoder1 -> SetDistancePerPulse(1);
                m_Encoder1 -> SetMaxPeriod(1.0);
                m_Encoder1 -> Start();
                double m_Encoder1Distance;
                double m_Encoder1Rate;
		void TeleopSensorUpdater(void)
			m_Encoder1Distance = m_Encoder1 -> GetDistance();  //Returns the amount of counts since the last reset
                        m_Encoder1Rate = m_Encoder1 -> GetRate();  //Returns the rate in pulses/second
2012-2015 - FRC 67 - Programming/Controls Lead Mentor
2003-2005 - FRC 857 - Driver
Check us out at http://www.hotteam67.org
Previous year design docs, programming tutorials, and more!
Unread 12-04-2012, 10:53
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
We do something similar to jsmeldru...
#include <PIDSource.h>
#include <Counter.h>
class freq_pid : public PIDSource {
private:
   Counter& count;
public:
   freq_pid(Counter& c) : count(c) {}
   double frequency() { return 1/count.GetPeriod(); }
   double PIDGet() { return frequency(); }
The nice thing for this is that it lets you use PID with a jag and such.
We take everything by reference since we centralize all of our sensor port data in one file.
Note that that frequency is in hz. If you want rpm you can just change the 1 to a 60.
Unread 12-04-2012, 16:05
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
This looks nice. Now, my question is how to integrate this with a PIDController and Jaguar to make a speed-based/rpm-based PID Control. We played with modifying PIDOutput() in a super-class of Jaguar such that it 'accumulated' rather than just sending the total_error to the Jag which effectively stops the Jag when you get to an error of zero (hence a positional PID controller as it is today)...
Seems that LOTS of people would want to be able to do this, but I wasn't able to find such a thing this year and so we tried creating our own and didn't have luck.
Anyone have experience here?
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 12-04-2012, 16:11
bob
For speed control of a shooter wheel, try this.
Unread 12-04-2012, 16:37
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
We have created a generic PID controller based on the WPI PID controller that, among other things, can handle speed control.
http://proj.titanrobotics.net/hg/Frc...b/TrcPIDCtrl.h
Unread 12-04-2012, 17:43
It's pretty easy actually. WPILib makes this easy for you.
We actually had two motors, so...
template<class T>
T coerce(T val, T min, T max) {
    if (val < min) {
        return min;
    else if (val > max) {
        return max;
    else {
        return val;
class two_jags : public PIDOutput {
private:
    Jaguar& jag1;
    Jaguar& jag2;
    float speed;
public:
    two_jags(Jaguar& a, Jaguar& b) : jag1(a), jag2(b), speed(0.0) {}
    void PIDWrite(float output) {
        speed = coerce(output + speed, -1.0f, 1.0f);
        jag1.PIDWrite(speed);
        jag2.PIDWrite(speed);
    void reset() {
        speed = 0.0;
Some integration code (note that we were working with a counter hooked up to a hall effect sensor detecting a single magnet in the wheel, so one tick was one rotation):
two_jags jags(jag1, jag2);
freq_pid freq(cnt);
PIDController shooter_ctl(0.005, 0.0, 0.002, freq, jags);
shooter_ctl.SetTolerance(4.0); //accept a 4% steady state error
shooter_ctl.SetInputRange(0.0, 75.0); //our max freq was 75 hz
shooter_ctl.SetOutputRange(-0.25, 0.25); //only ramp a little at a time
void enable_shooters(float freq) {
    jags.reset(); //zero out the accumulator
    shooter_ctl.SetSetpoint(freq);
    shooter_ctl.Enable();
You can do more stuff, like adding in a startup burst to get it close and then enable the PID controller to fine tune the speed. We ended up with a quarter second burst of full power before we started the PID controller. Make sure you set the starting speed (two_jags::speed) to your startup speed before, otherwise you'll put the motors back to zero power and defeat the whole purpose of the start speed.
Unread 12-04-2012, 18:28
mikets's Avatar
Software Engineer
Since you are using two motors, you should define the two motors in a sync group so you can synchronize them. BTW, I think you have a typo in the parameter of two_jags:: PIDWrite(float output);
Unread 13-04-2012, 10:04
Yeah, that (typo) is what happens when you're being lazy edited.
And I haven't heard of a sync group...
Anyway, what we had worked very well for us.
Unread 13-04-2012, 10:09
sync groups only apply when using CAN. PWM is always synced.
Unread 13-04-2012, 22:03
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
public:
shooter_motor(3),
shooter_motor2(4),
I think that the problem you are having is a side effect of wiring only the A channel. I think that in order to get the encoder to work with just the A channel, you will need to ensure that it is a "1x" encoder. (Note that I've never tried this, we always hook up both the A and B channels, even if we are only using "1x" counting.) To use 1X counting, when you initialize the Encoder, you will need to use a line like the following:
left_shooter(3,4,false,CounterBase.EncodingType.k1X)
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Last edited by Ken Streeter : 13-04-2012 at 23:22. Reason: fixing "code" snippet to be properly indented
Unread 13-04-2012, 22:15
To get the encoder to work with only one channel connected, you should use the Counter class instead of the Encoder class.
In the Counter class, you can specify either 1x or 2x decoding. I think it works this way: With 1x, it counts rising edges only. With 2x, it counts both rising and falling edges.
