Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Unread 08-01-2003, 17:40
Tton Tton is offline
#1089 (Team Mercury)
Tton is on a distinguished road
Send a message via AIM to Tton Send a message via Yahoo to Tton
What happens if your robot doesn't pass inspection?
T-ton
Unread 08-01-2003, 17:42
Noah's Avatar
Noah Noah is offline
Code Monkey
#0861 (The Gondobots)
Noah has a spectacular aura aboutNoah has a spectacular aura about
Send a message via AIM to Noah
Your not allowed to compete until you've rectified whatever prevented you from passing inspection. That means that you then have to go in for another inspection... and another... and another... until you get everything right.
"It's broken? NOOAAHH!!! This is your doing, isn't it!"
"We can fix it in the software!"
"It's a BROKEN GEAR!"
Unread 08-01-2003, 17:44
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
You go back to the pits and work your butt off to meet inspection...
~Adam
Unread 08-01-2003, 17:47
so you can modify at last secound to fit inspection. thank god! Sorry im a rookie. i have only watch competitions the last 7 years though lol.
T-ton
Unread 08-01-2003, 18:14
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
a little advice - build your robot underweight. it took us two hours to loose two pounds last year. the scale you have could be a little off.
Unread 08-01-2003, 18:20
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Inspection "What If"
I have been an inspector at several competitions for FIRST.
Easy answer: If you do not pass inspection you will not compete in the competition. Every effort will be made to get you to understand the needed changes so you can play.
Many veteran teams will jump in and give assistance, all you have to do is ask. Keep checking with the inspectors, they want you to pass, but with a safe, legal machine.
Bottom line: Your robot must be "Legal" and meet all the requirements that the other robots have met.
Mike Martus
Unread 08-01-2003, 19:23
mike thanks
and also it should be fun this year
T-ton
Unread 08-01-2003, 20:09
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
Plan ahead and don't be afraid to ask for help
In my experence, most inspection failures result from either weight, size(forgetting about that last fastener or appendage), or not following the construction rules before the competitions.
Make sure you follow the wiring rules and check your Bill of Materials against both the actual robot and the approved list of materials. That seems to be the best way to avoid ever failing inspection.
If you do fail and need help passing, virtually everyone at the competition will gladly assist you in making repairs. That is one of the most awesome things about the FIRST community.
Unread 08-01-2003, 21:05
DanLevin247 DanLevin247 is offline
Missing In Action
#0247 ('da bears)
DanLevin247 is on a distinguished road
Send a message via AIM to DanLevin247
Don't forget about SAFTEY GLASSES!
'daaaaaaaaaaaaaa bears!
It's all fun and games till someone gets hurt.....then it's hillarious!
Unread 08-01-2003, 21:22
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Don't ground the mounting screws on your light. This cost my team an hour last year.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 08-01-2003, 21:50
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
And also don't forget to give yourself around 5-10 pounds of weight when you ship it off because you can always add more weight for traction during the competition but it is a pain to try to get off even 3-4 pounds at the competition. Also take into account the width of the nuts and bolts, because if you make your robot exactly 30x36, your nuts/bolts/screws or whatever will make it 30.5" x 36.5", which means you can't compete
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
How to pass your inspection at Nationals, the EASY way Matt Reiland Championship Event 0 04-04-2003 18:39
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
