Go to Post Basically, just because you CAN do something doesn't mean you should and being savvy enough doesn't entitle you to being above the law. - Greg Needel [more]
Unread 07-04-2012, 20:11
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
pic: AndyMark 6in Right Mecanum Wheel
Unread 07-04-2012, 20:12
thenomnivore's Avatar
thenomnivore thenomnivore is offline
AKA: Ramirez
FRC #1212 (The Sentinels)
thenomnivore is an unknown quantity at this point
Re: pic: AndyMark 6in Right Mecanum Wheel
Me Gusta :3
A sandwich only gets tastier when defeated.
Unread 08-04-2012, 14:37
Thanks!
Unread 09-04-2012, 12:47
davetherobotman's Avatar
davetherobotman davetherobotman is offline
strategic systems design
AKA: Dave Woods
FRC #0537 (Charger Robotics)
davetherobotman is an unknown quantity at this point
Did you turn on ambient occlusion? It almost looks like you may have, but if you didn't definitely turn it on and you'll see quite a difference. I have created some very realistic views, even without using Photoview 360 and just using normal solidworks realview graphics. It could be the view angle and lighting that makes it look the way it does. You could also change the mapping size of the material appearances too, which can help show material "flaws" and textures better and give it a more realistic appearance.
I usually get real good results from Photoview 360 when you compare to its autodesk equivalent. I've tricked my boss by taking a photo of the actual product in a white booth, then rendering an image in photo view and asking him which one was the "Real" one. It's amazing how far the technology has come.
FRC#0537: '02-'06 (student), '07-'08 (mentor), '15-'16 (mentor)
FRC#2506: '07-'13 (advisor/co-lead)
FRC#5096: '13-'15 (advisor/co-lead)
Connect with me on LinkedIN
Unread 09-04-2012, 14:18
Originally Posted by davetherobotman View Post
... just using normal solidworks realview graphics. It could be the view angle and lighting that makes it look the way it does. You could also change the mapping size of the material appearances too, which can help show material "flaws" and textures better and give it a more realistic appearance.
I wish I could use the realview feature, however my Intel graphics do not support it.
virtual material flaws...now that's interesting.
Unread 13-04-2012, 19:45
AKA: Dave Woods
http://tinypic.com/r/x3v7ty/5
This is a bad example, but it shows a real view solidworks rendering (in this case, a nozzle) next to a picture I took of an actual existing part. In this particular case, i took the picture to highlight the fact that the drawings do not represent the final product (as you can see there are some profile differences). But none-the-less you can see that, without using any fancy "photoworks" or "photoview 360" package, you can still get fairly decent renders using standard screen shots from solidworks. All i did was turn realview graphics on and got rid of my black tangency lines.
