Re: 2012 Mid-Atlantic Robotics FRC Region Championship
And 1218 couldn't have driven away from the red bridge?
Is there a rule that says they have to?
Was their match goal to get 28 points in penalties?
The fact remains that it wasn't their own actions that caused those penalties, it was the actions of the other alliance. If [G45] wasn't intended to apply to that kind of scenario, what it is supposed to apply to?
it was their own actions, they parked in front of 341 in between them and the bridge. G28 also says there should have been a TF for consequential contact, i.e. instant 49 points for repetitive contact with the bridge.
But the direct cause of those penalties was the driving of the red alliance - if they had gone at the bridge from the other side, for example, there would have been no penalties. Also, [G28] assigns Technical Fouls only for purposeful, consequential contact, and this was not purposeful. Not really sure where you're getting the 49 points from, because the extra 40 points would come from [G25], which you can definitely not be forced into committing...
#7
Because it doesn't matter. If it happens it gets the penalty called no matter what.
#10
A. Yes, Rule [G25] applies throughout the Match. The Referee will determine if Rule [G44] applies given the exact circumstances. |
#12
Scott. Thanks for the ranking spreadsheet. You asked "Are there errors on the sheet or incorrect numbers there?" I believe 3974 should have 4 championship award points. 2 for Highest Rookie Seed Award and 2 for Rookie Inspiration Award.
Team 3974 (E=mCD) would like to thank everyone from the MAR District for making our rookie season terrific. The GP shown by all the teams was incredible. One question we heard many, many times at the events was “What does the mCD stand for". It is short hand for our school name Bishop McDevitt. |
#14
Violation: Technical-Foul and Red Card G44: Generally, a rule violation by an Alliance that was directly caused by actions of the opposing Alliance will not be penalized. Rule [G28] is an exception to this rule. and G28: Robots may not touch an opponent Robot in contact with its Key, Alley, or Bridge. Violation: Foul; Technical-Foul for purposeful, consequential contact. |
#15
If it was a strategy to rack up the penalties, [G45]. However, if a robot seems to be trying to play the game, say by knocking another robot away from the bridge, then that's not a strategy to rack up penalties, and no [G45]. YMTC. (And please let the refs at the event do the same--it's their call that counts.) |
