Go to Post theres no such thing as the best robot...cuz every robot is the best :D - [more]
Unread 14-04-2012, 16:41
Andrew Lawrence
Posts: n/a
Do you have to use 2x1x1/8" tubing for a WCD?
While I can use it, we've used .5x.5x1/8" steel tubing for our entire superstructure this year and found great success with it. Is there a reason for using the 2x1x1/8" tubing most teams use when making a WCD?
Thanks!
Unread 14-04-2012, 16:45
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Do you have to use 2x1x1/8" tubing for a WCD?
It fits the bearing blocks used for a west coast drive well. But if you can make the design work with something else, there's no reason that you have to use 2x1 tubing.
Unread 14-04-2012, 16:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Thanks!
It's the smallest size that can fit a bearing block for a live axle.
2001-2004: Team 100
2006-Present: Team 254
Unread 14-04-2012, 16:53
Andrew Lawrence
Posts: n/a
Thanks!
Unread 14-04-2012, 17:11
ttldomination's Avatar
Sunny
This is a bit of an aside, but is there somewhere I can look up some detail on these specific bearing blocks?
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 14-04-2012, 17:47
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
- Sunny G.
I would just search CD. Everyone does them a little differently, and it's not hard to find pictures and advice.
We tried 1/16" wall tubing on an offseason project for a WCD. It wasn't terrible, but the walls bent in around the bearing blocks. Definitely would not recommend it.
1625 has a nice drive with wider tubes to fit their belts inside the tube. http://www.chiefdelphi.com/forums/sh...ad.php?t=86668
Unread 14-04-2012, 19:41
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
We used 3 by 1.5 by .125 tubes this year for our WCD. They were pocketed with 2 inch diameter circular holes. Rather than slide our bearing blocks rotated in place, having 4 discrete positions to both tension chain and achieve proper center drop. We did this because it moved fabrication resources onto the frame that would otherwise have been devoted to the bearing blocks. We also used the larger tubes because they work a bit better with the rivets our team favors. In short, choose a tube size that works for you, smaller tubes favor teams that weld and use smaller wheels, while larger tubes favor rivets and gussets with larger wheels.
Unread 14-04-2012, 20:07
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Our team has used 1x3 1/8" the last 5 years.
Unread 14-04-2012, 20:19
Chris is me's Avatar
AKA: Pinecone
We used 3x1.5x1/8" the past two years in order to accommodate our internal belt drive. It's a weight penalty over other frame sizes, but a zero maintenance drive is REALLY nice.
Unread 14-04-2012, 20:20
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
A regular WestCoast with 2x1 is pretty much zero maintenance as well
Also saves you some weight!
-RC
R.C.
MadTown Robotics Team 1323
Unread 14-04-2012, 20:31
FRC #1836 (MilkenKnights)
-RC
Correct me if I am wrong Chris. But I believe he means no maintenance as the fact that they never have to tension their belt. On a WCD, you have to maintain it, though a very small job, by making sure the chain is tensioned, and adjusting the bearing blocks when the chain stretches.
Unread 14-04-2012, 20:51
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Thanks!
Now is it steel or aluminum, because steel would get really heavy after awhile.
Unread 14-04-2012, 21:04
Andrew Lawrence
Posts: n/a
It's steel, but it's surprisingly light. Our entire superstructure this year was under 60 pounds, which allowed us to switch out our entire frame with the steel by our second regional.
Unread 14-04-2012, 21:09
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
I think there needs to be some clarification in this thread. WCDs typically use 2x1x1/8in walled ALUMINUM tubing, not steel if I am correct. There is a huge weight difference between the two!
1058 PVC Pirates 2016 - xxxx
Unread 14-04-2012, 21:23
AKA: Pinecone
That is a large part of it. The other factor is that there are no exposed runs of chain to deal with.
I do not think 2791's drive is "better" than a traditional WCD, and the benefits of putting belt inside the tube rather than outside are somewhat marginal, but it works well for us and there is certainly something special about a drivetrain you literally never have to adjust.
