Go to Post Students learn from, are inspired by, and emulate their mentors. A team with a solid mentor base helps to create a productive, inspired, and ultimately successful group of students. - Jared Russell [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #61   Spotlight this post!
Unread 14-04-2012, 16:45
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: 2012 MSC
So why wasn't [G25] applied to 67 when there was a blue robot touching them while balancing?
  #62   Spotlight this post!
Unread 14-04-2012, 16:46
Re: 2012 MSC
Presumably because the robot falling onto them is covered by [G44]
  #63   Spotlight this post!
Unread 14-04-2012, 16:47
AKA: Simon Bohn
Re: 2012 MSC
That's an interesting usage of it. Has some very interesting connotations in the future if that holds true through championships.
  #64   Spotlight this post!
Unread 14-04-2012, 16:49
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: 2012 MSC
I wouldn't really say it affected the balancing... if anything, it helped the blue alliance because otherwise the falling robot is probably on its side.
Does anyone else remember when TBA signatures actually worked?
  #65   Spotlight this post!
Unread 14-04-2012, 16:59
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
Re: 2012 MSC
I agree with the way it was called, but I can see an argument for calling G35 on 67 because their presence prevented 548 from driving off the end of the bridge, preventing a double balance. That's sketchy at best, and I think the refs did the right thing. Another interesting observation is that after 67 died, 469 (I believe accidentally) pushed them closer to the blue bridge. If anyone wants to rewatch it it's uploaded here.
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
  #66   Spotlight this post!
Unread 14-04-2012, 17:01
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: 2012 MSC
Because 67 never touched the bridge directly. (At best, you could say 67 interfered with the bridge because the other robot fell on it, but then [G44] would apply and negate the foul.)
As for [G28], I don't know the circumstances of what happened with 67. If they E-stopped in that position (understanding the implications), there might be an argument to be made that the resulting contact was purposeful (and it was obviously consequential). On the other hand, sitting immobile isn't a very good indicator of purpose. I'd say the call on the field was a good one: one foul.
  #67   Spotlight this post!
Unread 14-04-2012, 17:18
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: 2012 MSC
I disagree...
Well if the robot was on it side, the blue alliance would have won.
There were no bridge points in the final match (F 1-2). This was because the robot 67 was contacting (preventing from tipping) was still in contact with the bridge. Had the robot not been in contact with the bridge, the blue alliance would have received 20 bridge points.
The final score was Red (469, 67, 830) 60 - Blue (2054, 548, 245) 49.
With blue getting those 20 BP, the final score would have been Red 60 - Blue 69.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #68   Spotlight this post!
Unread 14-04-2012, 17:19
tim-tim's Avatar
AKA: Tim Miedzinski
Re: 2012 MSC
Congratulations to 469, 67, and 830 for winning the MSC; which is no small feat!
The RoboBees
  #69   Spotlight this post!
Unread 14-04-2012, 17:22
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: 2012 MSC
Originally Posted by tim-tim View Post
I disagree...
And Blue should have (and would have) lost had it gone to a rubber match...67 was not moving nearly the entire match.
2001-2004: Team 100
2006-Present: Team 254
  #70   Spotlight this post!
Unread 14-04-2012, 17:27
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: 2012 MSC
And what if 67 had died for the last half of that rubber match and blue won? I think it still should have gone to a 3rd match
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #71   Spotlight this post!
Unread 14-04-2012, 17:38
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: 2012 MSC
A bad call at the end of a match doesn't warrant a new match, it warrants a review of the call, and adjustment of the score as necessary.
  #72   Spotlight this post!
tim-tim's Avatar
AKA: Tim Miedzinski
Re: 2012 MSC
I was not saying it would have changed the tournament outcome.
Losing comms, or whatever the issue was, happens. That was not the first time 67 had sat still for a good portion of the match during eliminations.
I am glad that Red won! I am very inspired by 469 and 67 machines. I can't wait to get an in person look at the robots in St. Louis!
The RoboBees
  #73   Spotlight this post!
Unread 14-04-2012, 17:42
dodar's Avatar
Re: 2012 MSC
And if the call had been changed blue would have won. Which, to me, would seem logical to warrant another match.
  #74   Spotlight this post!
Unread 14-04-2012, 17:49
Re: 2012 MSC
I disagree. At most, you can call a Tech Foul per [G28] which would still have given Red the win. I can't possibly see how a non-moving robot in the position 67 was in would not be [G44] protected from any potential [G25] call.
  #75   Spotlight this post!
Unread 14-04-2012, 17:53
Gray Adams's Avatar
Re: 2012 MSC
Why would it be G44 protected? No opponent put 67 where they were.
