Go to Post 7 divisions would be... interesting. - cadandcookies [more]
Go Back   Chief Delphi > Competition > Regional Competitions
  #76   Spotlight this post!
Unread 14-04-2012, 17:58
Re: 2012 MSC
Originally Posted by Gray Adams View Post
Why would it be G44 protected? No opponent put 67 where they were.
Because they weren't touching the bridge, hence no possible way to incur [G25] by themselves, if they were to be moved into contact with the bridge it would have had to have been by the opposing alliance.
[G25] Robots may not contact or otherwise interfere with the opposing Alliance Bridge.
Note: I am suggesting that the appropriate call for hitting the overhanging edge of a robot on the bridge, per the rules as written, is a Tech foul [G28] even if that contact unbalances a balanced bridge or otherwise interferes with balancing. The "If the act...." section of G25 is written as part of the "Violation" section which means that it is used to stipulate the penalty for violating the rule which requires a violation of the rule itself to begin with (touching the bridge).
  #77   Spotlight this post!
Unread 14-04-2012, 18:11
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: 2012 MSC
G25 doesn't say you must contact the bridge for the violation to be incurred. It implies that there are ways to interfere with balancing that don't involve contacting the bridge. The balance attempt was clearly interfered with by 67, by definition of interfere. Though that doesn't mean it changed the outcome, its certainly enough to make a case for G25.
  #78   Spotlight this post!
Unread 14-04-2012, 18:42
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: 2012 MSC
It's true that [G25] doesn't require actual contact for interference.1 However, if the interference was directly caused by an opponent's action (even if there were other direct causes), [G44] is triggered and [G25] is waived. It doesn't matter that 548 didn't intend to fall on 67; only that they did, that the bridge was interfered with, and that 548 was a direct cause of the interference.
1 Thought experiment: a robot has an earthquake machine and directs it at the floor to unseat the opponents' bridge. [G25] would seem to be appropriate.
  #79   Spotlight this post!
Unread 14-04-2012, 18:49
Gray Adams's Avatar
Re: 2012 MSC
Well now you're in G45 territory for using G44 to waive G25.
  #80   Spotlight this post!
Unread 14-04-2012, 20:31
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Re: 2012 MSC
Wanted to thank 2054 and 245 for being great alliance partners and getting us all the way to the finals.
Congrats to 67, 469, and 830. Very scary alliance and a well deserved victory!
Hope to see all of you at St. Louis and hope to meet again behind the same glass in eliminations there!
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
  #81   Spotlight this post!
Unread 14-04-2012, 20:55
JABot67 JABot67 is online now
Unregistered User
AKA: John Bottenberg
FRC #2930 (Sonic Squirrels)
JABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond repute
Re: 2012 MSC
What a great, high stakes competiton! Always great to see HOT win (and to give them a run for their money in quarters 1 match 2). I have a lot to say about the many great teams at the event. but unfortunately I have other things on my mind.
I lost a blue and gray checkered (kind of) hoodie that contains my car keys at the competition. It was on the table in our pit after our last quarterfinals match, and then disappeared. I looked everywhere I had been including the stands and the pit, and my team searched through all our stuff and couldn't find it. We talked to pit admin and to the event coordinator and they weren't able to help me.
Nobody moved it, so barring someone walking into our pit and just taking it, we think what most likely happened is it got bumped into the pit behind us belonging to Team Excel, 2474. They packed up very quickly and were gone the next time anyone from our team was in the pit. 2474, it would really help me if you could check to see if you have my hoodie and keys.
I know what I have to do now that my keys are gone; I am just wondering if anyone has seen the hoodie or has any idea where I could find it. What do they do with the lost and found items after the competition?
John Bottenberg - University of Michigan '14 - Microsoft
FLL Team "Dark Matter": 2003-2005
Robofest Team "Dark Matter": 2005-2008
Team 67 Programmer: 2007-2010
Team 3322 Programming Mentor: 2012-2014
Team 2930 Engineering Mentor: 2015-????
  #82   Spotlight this post!
Unread 14-04-2012, 21:01
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
Re: 2012 MSC
Who won Chairmans, EI and RAS?
2012-Present Wave Robotics Team 2826
  #83   Spotlight this post!
Unread 14-04-2012, 21:03
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: 2012 MSC
I am pretty sure all lost and found gets sent to FIRST Headquarters. I am not 100% though.
Hope you find your hoodie and keys!
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #84   Spotlight this post!
dodar's Avatar
dodar dodar is online now
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: 2012 MSC
Chairmans: 27, 33, 503
EI: 1718
RAS: I dont remember.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #85   Spotlight this post!
Unread 14-04-2012, 21:15
StephenK StephenK is offline
FRC #1718
StephenK is an unknown quantity at this point
Re: 2012 MSC
4130 Blue Devils won RAS
  #86   Spotlight this post!
Unread 14-04-2012, 21:19
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: 2012 MSC
That was particularly sweet for us - they are a rookie team we started this year and build in our build space. We're in the process of helping them with funding for the trip to St. Louis, and possibly getting them a ride down there.
Go Blue Devils!
  #87   Spotlight this post!
Unread 14-04-2012, 21:45
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Re: 2012 MSC
Go Blue Devils!
Build them a Crate! Fast! That's what Team 1511 did for our Regional's Rookie All Star team. Actually we made it in advance and presented it to the winner after they won.
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
  #88   Spotlight this post!
Unread 14-04-2012, 23:06
AsianPersuasion's Avatar
AsianPersuasion AsianPersuasion is offline
AKA: Justin M.
FRC #0240 (Tempest)
AsianPersuasion is an unknown quantity at this point
Re: 2012 MSC
Great match, congrats to the winnings alliance! The wave from the stands http://www.youtube.com/watch?v=wjep3...ture=mh_l olz
  #89   Spotlight this post!
Unread 15-04-2012, 00:06
Debbie's Avatar
Debbie Debbie is offline
AKA: Debbie May
FRC #1023 (Bedford Express)
Debbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond repute
Re: 2012 MSC
Go Blue Devils!
How many of them are there? We may have room on our bus.
FRC 1023 - Bedford Express - Coach, 2009 - present
FTC 160 - Dana Broncobytes Coach - 2007 - 2009
FLL - Dana Unicorns Coach - 2000 - 2006
Bedford Express Varsity Letter Video BX Facebook
  #90   Spotlight this post!
Unread 15-04-2012, 04:32
AKA: Justin M.
FRC #0240 (Tempest)
Re: 2012 MSC
The wave http://www.youtube.com/watch?v=wjep3WMjm3Y
