Go to Post Keep your chin up, your safety glasses on, and don't let the magic smoke out of the electrical components and you'll do just fine :) - rsegrest [more]
Unread 08-01-2003, 20:46
PyroPhin's Avatar
PyroPhin PyroPhin is offline
None #0263
PyroPhin is on a distinguished road
Optical Sensor Questions
been playing with the Edubot and the optical sensors in this years kit at home for the past couple of days.. and i noticed someting a little pecular about them.
they will sense other surfaces then Retroreflective tape.. i hold my hand in front of them and thet trigger. also.. i built a model of the sensor array we plan for the bot this year and im finding out that the sensors have a hard time tracking white on red. im using construction paper, but i dont have any carpet.
anyone else encounter this problem or a simalar one?
the other thing is.. that im not totally shure about the tracking lines on the field this year, are they made with retroreflective tape or is it just a strip of white duct tape
~Pyro
Squee!
Team 263, Aftershock:
Alumni, guy who comes back and fixes Krass's mistakes
Unread 08-01-2003, 21:27
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
It's actually more of a cloth tape. The reason for this is that it stretches to make the 4' radius better. The sensors don't require retroreflective tape, they can also detect differences between light and dark.
Unread 08-01-2003, 21:30
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
The sensors sense an infrared beam that they emit. The infrared will reflect off other surfaces though different surfaces will work better or worse. You probably noticed that when you use your hand, it has to be quite close to sense it...
The white lines are made with vinyl tape that is 2" thick. The actual tape used is Shurtape, PC-628 Premium Grade Tape, Vinyl Coated Cloth, White, 2" Wide that can be purchased at www.tapemonster.com. See section 10.4 in the "Game" section in the manual (http://www2.usfirst.org/2003comp/The_Game.pdf).
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 09-01-2003, 00:06
Aashish Aashish is offline
Aashish is an unknown quantity at this point
you can also adjust the the little screw on the back of the sensor to decrease or increase the difference between white and dark or other colors
just play around with the screw on the back
Unread 31-01-2003, 12:53
Team852 (DB) Team852 (DB) is offline
#0852 (The Athenian Robotics Collective)
Team852 (DB) is an unknown quantity at this point
Team 852 has had the same problem.
I believe that the sensors emit and track red light (low frequency within the visible spectrum), not infrared. I still need to look at the charts they sent us.
Red light emitted from the sensor reflects very well off of red paper (Red paper is red because it reflects red light, and absorbs a good bit of the other frequencies).
We have not tried it on red carpet, and wonder if anyone else has made such an attempt. Of course, if so, what were the results?
-DB, The Athenian Robotics Collective
optical sensors majormusic2005 Electrical 5 11-03-2003 21:32
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors great_one411 General Forum 1 15-02-2003 19:54
optical sensors majormusic2005 General Forum 1 28-01-2003 20:37
OPTICAL SENSORS??????????????????? NM_programming Technical Discussion 2 13-01-2002 17:41
