Go to Post The only people who are dumb or ignorant in this world are the ones who don't stop and ask why. - T967 [more]
Unread 15-04-2012, 07:57
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Change size of text field in Smart Dashboard?
Greetings!
We're trying to bring the RPM of our shooter back to the driver station during the match. But, the size of the standard text field on the smart dashboard is way too small. I've looked at the text properties, but I don't see a text font/size property. Is there a way to modify the text display in the smart dashboard to change the font size and color? We're a C++ team. But, we've got Java folks as well which is why we're looking at the smart dashboard.
TIA,
Mike
Unread 15-04-2012, 09:25
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Change size of text field in Smart Dashboard?
There is currently a bug filed in the SmartDashboard tracker.
Unread 16-04-2012, 20:34
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
I actually wrote a little extension for my team that replaces Label and can read values from a NetworkTable, inserting them into a string. I don't know if C++ has a NetworkTable implementation, but if so this might be helpful.
Most of the properties are self-explanatory, but two things you want to keep in mind:
  • Network Table is the name of the chosen network table. To access it on the robot side, use NetworkTable.getTable("My table name"). The robot-end and SmartDashboard-end names must be the same for this to work.
  • The format string acts like a normal label string, except that everything within % symbols is treated as a key, and gets replaced with the contents of that NetworkTable entry. For example, a format string "Shooter speed: %shooter.rpm%rpm" will display as "Shooter speed: 50000rpm" when your motor is about to explode.
And now, the code:
package storm.smartdashboard;
import edu.wpi.first.smartdashboard.gui.StaticWidget;
import edu.wpi.first.smartdashboard.properties.*;
import edu.wpi.first.wpilibj.networking.NetworkTable;
import java.awt.BorderLayout;
import java.awt.Color;
import javax.swing.JLabel;
 * @author Joe Doyle (Ginto8)
public class SmartLabel extends StaticWidget {
    public static final String NAME = "Smart Label";
    private static NetworkTable SMARTDASHBOARD_FEEDBACK;
    private static String format(String s, boolean plusPositive) {
        String ret = "";
        int start = 0, end = 0;
        while (true) {
            start = s.indexOf("%", end);
            if (start < 0) {
                break;
            ret += s.substring(end, start);
            end = s.indexOf("%", start + 1);
            if (end < 0) {
                end = start;
                break;
            String key = s.substring(start + 1, end);
            Object value = SMARTDASHBOARD_FEEDBACK.getValue(key, null);
            if (value == null) {
                ++end;
                ret += s.substring(start, end);
                continue;
            String out = value.toString();
            if (plusPositive) {
                Double asDouble = (Double) value;
                Integer asInteger = (Integer) value;
                if (value instanceof Double && asDouble.doubleValue() >= 0) {
                    out = "+" + out;
                } else if (value instanceof Integer && asInteger.intValue() >= 0) {
                    out = "+" + out;
            ret += out;
            ++end;
            start = end;
        ret += s.substring(end);
        return ret;
    public final StringProperty netTable = new StringProperty(this, "Network Table","Feedback");
    public final StringProperty text = new StringProperty(this, "Format String", "%DEFAULT%");
    public final DoubleProperty fontSize = new DoubleProperty(this,"Font Size",12);
    public final BooleanProperty plusPositive = new BooleanProperty(this,"Always show sign",false);
    public final MultiProperty horizontal = new MultiProperty(this, "Horizontal Alignment");
    public final MultiProperty vertical = new MultiProperty(this, "Vertical Alignment");
    public final ColorProperty textColor = new ColorProperty(this,"Text Color",Color.black);
    private volatile JLabel label;
    Thread updateThread;
    public SmartLabel() {
        this.horizontal.add("Left", Integer.valueOf(2));
        this.horizontal.add("Center", Integer.valueOf(0));
        this.horizontal.add("Right", Integer.valueOf(4));
        this.horizontal.setDefault("Center");
        this.vertical.add("Up", Integer.valueOf(1));
        this.vertical.add("Center", Integer.valueOf(0));
        this.vertical.add("Down", Integer.valueOf(3));
        this.vertical.setDefault("Center");
        updateThread = new Thread() {
            @Override
            public void run() {
                while(true) {
                    update();
                    try {
                        Thread.sleep(1000 / 5);
                    } catch (InterruptedException ex) {
    private synchronized void update() {
        this.label.setText(format(this.text.getValue(),plusPositive.getValue()));
    @Override
    public void init() {
        setLayout(new BorderLayout());
        SMARTDASHBOARD_FEEDBACK = NetworkTable.getTable(netTable.getValue());
        this.label = new JLabel(format(this.text.getValue(),plusPositive.getValue()));
        this.label.setHorizontalAlignment(((Integer) this.horizontal.getValue()).intValue());
        this.label.setVerticalAlignment(((Integer) this.vertical.getValue()).intValue());
        this.label.setFont(label.getFont().deriveFont(fontSize.getValue().floatValue()));
        this.label.setForeground(this.textColor.getValue());
        add(this.label, "Center");
        updateThread.start();
    @Override
    public void propertyChanged(Property property) {
        if (property == this.text || property == plusPositive) {
            update();
        } else if(property == this.fontSize) {
        } else if (property == this.horizontal) {
        } else if (property == this.vertical) {
        } else if(property == this.textColor) {
        } else if(property == this.netTable) {
Unread 17-04-2012, 00:55
Gigakaiser Gigakaiser is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Gigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant future
If you change your field to a "formatted field" and check the properties menu, text size is an editable number.
FRC Team 987 - It's not enough
Unread 17-04-2012, 07:36
Software Mentor
AKA: Mike Anderson
Thanks, Radical. I'll take a look at that.
Mike
