Go to Post The GDC is becoming sane. - Zuelu562 [more]
Unread 07-01-2003, 22:06
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
My team is toying with drivetrain ideas .. .
you be the judge. This is the most radical (that we are considering)
You have two wheels in front. They are your drive wheels. They are powered through a differential . . . . .
You have one 'wheel' in back. like monsieurcoffee's teams omniwheel from the gallery:
http://www.chiefdelphi.com/forums/pi...&quiet=verbose
the wheel is perpendicular to your direction of motion . . or whatever, its just sideways. Ours would probably not by that robust as it is not going to support very much load.
Anyway, the pluses we see with this drivetrain are as follows:
1- low energy turning. We only need to spin a smaller motor to turn, unlike a tank tread bot where you need to use the same power to turn as you do to go full speed.
2- need for only one transmission . . Your wheels are not driven independantly, so only one transmission/gearbox is needed.
3- your axis of rotation will be the midpoint between your front wheels when you are stopped. with some designs we are playing with this will allow us to spin aroung a box to acheive a better angle without even touching our main drive.
4- did i say you only need one transmission? cheaper.
possible drawbacks
1- you need to build/aquire a differential. If you aquire it and it fails, diffiult/impossible to replace/repair.
2- the three wheel design may be prone to tipping, especially when on the ramp.
3- an omni wheel, as monsuier(however thats spelled) coffee calls it, will need to be machined. . . . we would probably use rollerblade wheels or something, tho, it would need to be able to get across those little 'lips' on the start of the ramp easily.
So, did I just describe something you already have been using?
is it feasible?
should we do it?
I really agree with my physics teacher: he saw us turning our edubot (4 wheel drive version) by reversing one side . . and laughed at how inefficient that was.
Unread 07-01-2003, 23:06
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
My (newbie ) assessment:
I agree with all of your plusses
"1- you need to build/aquire a differential. If you aquire it and it fails, diffiult/impossible to replace/repair."
I would agree with you, there.
"2- the three wheel design may be prone to tipping, especially when on the ramp."
Add two caster wheels on the two previously "un-wheeled" corners!
"3- an omni wheel, as monsuier(however thats spelled) coffee calls it, will need to be machined. . . . we would probably use rollerblade wheels or something, tho, it would need to be able to get across those little 'lips' on the start of the ramp easily."
If your omni is behind your main drive wheels, it will have more traction than it would on a level surface. Roller blade wheels would potentially grip relatively well if you made little nicks in them, I would think...
Overall, it sounds like a cool idea
Unread 07-01-2003, 23:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
did I miss how it was going to turn? Steering brakes perhaps? Or was it that the omni wheel is powered and sideways?
Unread 07-01-2003, 23:32
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I don't remember the rule number exactly, but i'm pretty sure this year you can't use metal on your wheels. (well metal studs, but i think the sideways rolling sections would count.) That would require that you make those sections out of rubber. Which i think is slightly tougher, but is probably still possible. Good luck on making them though. My team is probably sticking to the inflatable rubber wheels.
Team Website
Unread 08-01-2003, 10:59
#1067 (SLUH)
Not metal wheel things, but rollerblad wheel type stuff . . . we can find em at used sports stores for cheap.
yah, the back wheel is powered, thats how it turns. Actually, things are looking up for us, we ca probably do this.
(original chassis! WOO FOR US!)
Unread 08-01-2003, 17:27
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Any type of wheels are allowed this year... and by any manufacturer.
You could buy Omni Wheels if you can find them... just do a google search for "Omni Wheel".
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 08-01-2003, 18:47
#1067 (SLUH)
I got outvoted, my team opted for standard 4 wheel drive.
They have no sense of adventure.
And I'm lead designer. #%#%#%#%. Most of their protest centered around the omni wheel, maybe if they knew we could buy em they would change . . . . . some of the wheels are like 50 dollers tho. Heavy duty, tho, probably all we need and more. we have 1000 extra as of now, hoping for more, later.
Maybe I can talk them into it . . . this design is just soo, cool.
ah well, maybe next year when we are not a rookie team. I'll be a senior them, maybe captain, if im lucky.
Unread 08-01-2003, 18:58
I'm sorry to hear that but keep this in mind. A really cool design might not be the one that will have you place highest in the Qualifying Matches. However a really cool design could get you picked for finals. This is something jumbling in my head right now but I can't say a whole lot about it. Top-secret stuff.
<edit>On second thought, your design would be very maneuverable but essentially have only two wheel drive and a caster in the back (the omni would be a little better than a caster). This could be a problem for going up the ramp. But a very cool design none the less</edit>
Unread 08-01-2003, 21:48
#1067 (SLUH)
some of the omni's I saw on sale have pretty big contact wheels . . . should be no problem . . . you could put both chiaphua/atwoods and both bosch drill motors/transmissions into your differential, and that way you could go anywhere with torque to spare.
Bah. They don't want to even build a stacker. Cowards. We settled on a boring bulldozer/4 wheel drive bot. Man, I wish I was in charge (so that we could show up at regionals with a half-completed bot).
Unread 10-01-2003, 10:10
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
i am probably going to get killed for saying this, but our team is going to do a walker this year... dont ask, but u will have to see it to believe it
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 10-01-2003, 10:21
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
No Differential Required
You really don't need a differential to do what you want. A while back I used to own a Suzuki 4-wheeler. At the time, virtually no 4-wheelers existed with a differential (I don't know about these days). The point is, you can have steering with no differential - it's not that bad.
For cars, the differential makes the steering a bit more stable, but one of the biggest reasons for the differential is for tire wear. Since you're building a short lifespan robot, I wouldn't worry about one side slipping a little bit.
In fact, I would argue that a differential could be a bad thing. Have you ever seen a car with a standard differential on a slippery surface? What happens is that the differential causes more power to go to the wheels that have less traction (that means you'll have one wheel that's spinning like crazy while the one that has tractions is sitting there doing nothing). That's not good for this competition.
Unread 10-01-2003, 20:29
#1067 (SLUH)
read the design. the differential is a crucial, vital part.
Unread 10-01-2003, 21:52
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Anytype of wheel that doesn't violate rule M17.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
