Go to Post Maybe FIRST made these bumper rules so IRI would have something to blow off come July. - Koko Ed [more]
Unread 16-04-2012, 02:23
NIhunter's Avatar
NIhunter NIhunter is offline
AKA: Nicolas Hunter
FRC #2709 (Iron M.A.W.)
Team Role: Driver
NIhunter is an unknown quantity at this point
CIM limited to one direction
We are using 4 CIM motors for a 8 inch mecanum drive. The robot goes forward normally and can strafe in one direction flawlessly. The problem occurs while moving backwards. As 2 CIM motors do not turn the other direction. We are using Toughbox Nano gearboxes if that helps. The jaguars blink red but the wheels refuse to turn. We were demonstrating the robot when we noticed the problem. So we did not have much time to troubleshoot. I will swap the pwm's and check the voltage going to the motors shortly. I was Just wondering if anybody had a problem like this and if they found a solution.
Unread 16-04-2012, 03:27
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: CIM limited to one direction
I suspect that when you mounted the CIMS, they somehow managed to be a few degrees out, this can cause a gearbox to seize and would explain your problems.
I'd dismount the CIMS from the tough boxes, test them, and remount. This will tell you if it's a problem localised to the CIMS, or your drive train.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 16-04-2012, 07:00
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Read this thread:
http://www.chiefdelphi.com/forums/sh...44&postcount=3
See if that's your issue.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 16-04-2012, 09:14
NI,
The Jaguars do have a failure mode where they only operate in one direction. The first check is to lift the robot and operate the joysticks to see if it works.
Unread 16-04-2012, 10:27
silverD's Avatar
silverD silverD is offline
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
silverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to behold
Make sure the limit switch jumpers are seated properly. If the jumpers are not shorting the pins, the jag will not allow the motor to spin in the direction of the open circuit.
Unread 16-04-2012, 10:55
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
We have a Jaguar that only commands voltage in one direction. I tried re-flashing it but it didn't help. Is there a way to reset it?
Unread 16-05-2012, 08:48
greasemonkey's Avatar
greasemonkey greasemonkey is offline
Truss me I'm a Doctor
AKA: Fred Parker, fredword, fredwardo, phred, frederick
FRC #3467 (windham windups)
greasemonkey is an unknown quantity at this point
this happened to us this year for us the problem was a couple of bad jaguars have you tried changing them out? if it is not that then it ma be that your cims are bad or mounted incorrectly.
