Go to Post No matter what happens to the robot we learned our lesson and we had fun. That's what matters. - David Guzman [more]
Unread 16-04-2012, 02:23
FRC #1836 (MilkenKnights)
Sponsor Logos
Team 1836 is looking for a new way to do sponsor logos. Before we have done polycarb with clear stickers, but it really looks ugly. We have seen much better ways of doing the same, such as what the Poofs, the Holy Cows, and many other teams do. What type of sticker is used on their polycarb. Or does anybody have better ideas that they would like to share?
Unread 16-04-2012, 02:39
twetherbee twetherbee is offline
Mentor, Team 987
FRC #0987 (High Rollers)
twetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud of
Re: Sponsor Logos
Find a used or new small vinyl cutting plotter and make your own graphics. Same machines that sign companies use. You can find small ones (24"-30" roll width) new for a couple hundred dollars.
Unread 16-04-2012, 10:09
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Sponsor Logos
Our team glues paper onto the polycarb side panels, but integrates them into the paint scheme so they look better. Some "ugliness" might stem from implementation, not the quality of your logos, but not having see your robot, I really have no idea.
-Plutarch
Unread 16-04-2012, 10:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Sponsor Logos
x2 for vinyl cut. We got ours from USCutter and it works great.
Unread 16-04-2012, 10:24
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Sponsor Logos
IMO, if you're doing decals on polycarb and you want them to look good, die cut vinyl (also called Kiss Cut by some) is the ONLY way to go. Depending on your budget, you can invest in your own cutter or find a local shop to do them for you or look into someone like Two Pencil Designs.
-Dustin Benedict
Unread 16-04-2012, 12:40
mom-bot's Avatar
mom-bot mom-bot is offline
Engineers run on cookies
AKA: Ms. Reis
FRC #0175 (Buzz Robotics)
Team Role: Marketing
mom-bot is an unknown quantity at this point
Re: Sponsor Logos
Another route so you don't have to buy a machine:
You can print or have this printed on photo paper the more graphical logos then have them laminated. This provides a reasonable priced high quality look. We typically use 600dpi so even when enlarged the logos are crisp. Vector graphic work well also.
Some print shops have the ability to print large photos or graphics from a computer file, then do laminating up to 48" wide. Finding the folks that can do the laminating is the trick. Warehouse clubs with photo services have large sizes including poster prints available at pretty resonable prices.
These may then be attached to the polycarb with sticky velcro. This is great if you want to use an area for graphics you still need access to for repairs, upgrades, etc. Look for square tube, angle pieces or surfaces to attach the velcro and it will work well for you.
Unread 16-04-2012, 12:56
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Re: Sponsor Logos
This year, 1515 ran out of time for vinyls, so we bought 8.5x11" Clear Label paper from Staples and printed them on our laser printer. We cut them out by hand.
Of course, this is less than ideal, and really didn't come out as well as I had hoped. Your sponsor logos looked better than ours (IMO), so either stick with what you are doing or go to die-cut vinyl prints. I also suggest you contact TPD for this, they seem worth supporting with business.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 16-04-2012, 13:01
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: Sponsor Logos
148 has also used vinyl cut logos for a few years now - we know someone locally that has one in their home shop. It's a little tedious getting all the little pieces to stick and not lose pieces (the center of the "A" in the Innovation First logo always seems to be an issue...) but they look really sharp. We'll even stack multiple colors to get our red-on-white 148 number decals.
Jeff Waegelin
Unread 16-04-2012, 13:04
Re: Sponsor Logos
Thank you so much everybody. It seems like vinyl is the way to go, and we will most likely be able to get our head mentor to invest in the machine.
Unread 16-04-2012, 21:42
Re: Sponsor Logos
Our vinyl cutter was about $300 and has easily paid for itself in this season alone.
Unread 17-04-2012, 08:24
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Sponsor Logos
We had a local printer that does car wraps & signs print our sponsor boards on stock sign material that is kinda like sturdy foam board. Just gave him a adobe illustrator file.
Unread 17-04-2012, 10:25
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Re: Sponsor Logos
Team 1511 got ours designed and manufactured by Two Pencil Designs! http://twopencildesigns.com/wp/ They are beautiful and so much more professional then our normal way of transparent stickers on lexan! And the company is a dream to work with!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
