Go to Post One must agree that a Bus full of FIRSTers is always Fun'n Frolic. :) - RoboMadi [more]
Unread 08-01-2003, 22:13
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Falling bins are like dice
Falling bins are like dice. Well, weighted dice. Has anyone figured out through experiment what the probability is of which side coming up is? It's only useful if you simulate real match events (having them fall down a ramp for instance). Any numbers would be helpful
My guess is
face up - .2
face down - .4
"long" side - .3
"short" side - .1
But I would like real stats (mean probability and SD or varience would be good).
Thanks
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 08-01-2003, 22:21
DanLevin247 DanLevin247 is offline
Missing In Action
#0247 ('da bears)
DanLevin247 is on a distinguished road
Send a message via AIM to DanLevin247
Oh my goodness, 10th grade math!!!
/me dies
'daaaaaaaaaaaaaa bears!
It's all fun and games till someone gets hurt.....then it's hillarious!
Unread 08-01-2003, 22:28
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
i would guess the face dow (upsidedown) would be about 60% as most of the weight is there. You could cacluate the center of gravity and then based on what angle it land you could predict how it will land. GAHHH!!! lets just say it prolly wont be pretty.
Where has all the fun gone?
Unread 08-01-2003, 22:31
Missing In Action
#0247 ('da bears)
Trashed makes a point, and I realized that I didn't learn how to do probability equations for uneven sides, trajectories and whatnot in 10th grade
Unread 08-01-2003, 22:32
MBiddy's Avatar
MBiddy MBiddy is offline
Groovy!
#0862 (Lightning)
MBiddy is an unknown quantity at this point
Send a message via AIM to MBiddy
Probability is a horrible horrible subject.
Unread 08-01-2003, 22:35
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
What's the chances of them breaking?
My guess is like one box will only last 3 matches.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 08-01-2003, 22:38
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
depends too much on how you hit at and what you hit it with how hard.
however, thats a good point about them being topheavy. you also have to consider that its hader to balance on the handle ends. the top face is also larger so it would be less likely to continue tubling. same goes for the sides because of the lip.
Unread 08-01-2003, 23:26
Joe Menassa Joe Menassa is offline
Professional Photographer
FRC #0078 (Air Strike)
Joe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud of
Send a message via AIM to Joe Menassa
I have found that most fall on their side, the long way. this is the side that has the most room for them to fall on to. Also when you push over a high stack they fall together in a line, preventing them from landing any other way than on their side.
Joe Menassa
FRC 78
Unread 08-01-2003, 23:28
D@ve's Avatar
D@ve D@ve is offline
Make it Happen
AKA: David Ferreira
D@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of light
Send a message via AIM to D@ve
Joes right on this one .We tested it out more than once and every time the fell the same way. Without anything underneath!
Unread 09-01-2003, 00:03
Simeon Simeon is offline
#0820 (DeltaTech)
Simeon is an unknown quantity at this point
to our surprise, once in a while they land on their side, the tall way...
but yes, most of the time, it's the long way side.
i suppose when u have the tall way, u can just run the robot at the bin, changing it into the long way.
Unread 09-01-2003, 00:07
EStokely's Avatar
EStokely EStokely is offline
AKA: Eric Stokely
FRC #0360 (Revolution)
EStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond reputeEStokely has a reputation beyond repute
I think the reason they don't end up on thier lids more often is the way they are stacked when they fall. The tend to act as anti roll devices to each other as the come down.
We also noticed most were on thier long side after a wall was hit (all done without a ramp yet)
Certainly creates a new level of complexity. "righting" a side ways box.
Eric Stokely
Team 360 The Revolution, past mentor of 258 The Sea Dawgs
Experience is what you get when you don't get what you want.
Unread 09-01-2003, 00:11
#0820 (DeltaTech)
heh.. or in that case, maybe our robot should go out with duct tape fixing up all the broken boxes... maybe then we'll get bonus points.
Unread 09-01-2003, 02:24
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
Also you have to take into account how high the boxes are when they are dropped to see which side lands face up because the lower it is in the air, the less the center of gravity would matter because the less time the box would have to turn.
Unread 09-01-2003, 08:05
Alex Forest's Avatar
Alex Forest Alex Forest is offline
MadHatter
#0190 (Gompei and the H.E.R.D.)
Alex Forest is an unknown quantity at this point
Send a message via AIM to Alex Forest
You also have to take into account the fact that a lot of them aregoing to be landing onthe ramp, which is NOT a flat surface, and just going to mess up all those calculations again... *sigh*
Ahh...the wonderful and new experience of being a college mentor. Wow. its very disturbing to have people thinking that I know what I am doing....*shudder*
Unread 09-01-2003, 11:11
Digo's Avatar
Digo Digo is offline
AKA: Rodrigo Ribeiro
#0383 (Brazilian Machine)
Digo is on a distinguished road
Send a message via MSN to Digo
The Pathfinder landed on Mars inside a pyramid that would always be with the robot's base side on the floor after bouncing.
Maybe its creator didn't want us to have such an easy solution for this problem.
Rodrigo Ribeiro
Team #383 - The Brazilian Machine
Mechanical Engineering student at UFRGS - Porto Alegre - RS - Brazil
What do you YOU use your bins for? AlbertW General Forum 40 13-04-2003 04:18
Animating Falling Bins with Real World Dynamics mixmasta321 3D Animation and Competition 17 08-02-2003 22:44
robot touching a stack of bins carlye Rules/Strategy 20 11-01-2003 02:13
tipped bins cbudrecki Rules/Strategy 25 07-01-2003 23:12
How will the bins face on the ramp? Jacqui Sutton Rules/Strategy 1 07-01-2003 08:48
