Re: FTC CAD Part Help
I don't see 416mm channel in the Kit of Parts. If you need a model, I can send you one. You can make it yourself using hole patterns. Or, if you haven't used hole patterns yet, you can assemble it from two 288mm models. Cut one 13 holes long (use a cutting extrusion to remove the excess) and the other 12 holes long. Then assemble the two end to end.
Not sure why that was not included but I have attached one I created by editing one of the shorter channels. It's easy when they are parametric
