Go to Post [A screen shot] is very helpful - I've sent Brandon many of those the various times I've broken ChiefDelphi.com! - Jessica Boucher [more]
Unread 08-01-2003, 22:41
Tton Tton is offline
#1089 (Team Mercury)
Tton is on a distinguished road
Send a message via AIM to Tton Send a message via Yahoo to Tton
Is it illegal to lift another robot off the ground?
is it illegal to lift an opponents robot of the ground
T-ton
Unread 08-01-2003, 22:43
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
You actually will get more points if you are on the ramp at the end of the game and there's a robot on top of you- so that should be allowed as long as you are not damaging the robot itself
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
yes, red the rules-it's in there... b-leve me it's there
edit- u beat me
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 08-01-2003, 22:54
Timinator Timinator is offline
Timinator is an unknown quantity at this point
I must have missed the part where you get more points for carrying a robot at the end. I beleive it says a robot completely supported by a robot completely on the top will receive the 25 points as well, but I can't find it
Unread 08-01-2003, 22:56
not on CD enough...
I never actually saw it in the manual but Woodie and the NASA guy talked about it during the kickoff.. maybe they were mistaken- that's completely possible
Unread 08-01-2003, 22:58
Simeon Simeon is offline
#0820 (DeltaTech)
Simeon is an unknown quantity at this point
the idea is that when a robot sits on top of another robot, the top robot inherits the properties of the bottom robot.
if it is a blue robot on a red one
the top robot is counted as a red robot
let's say the bottom robot manages to get to the top of the hill
therefore 2 red robots are now sitting on top of the platform, giving the red team 50 points
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
In print > spoken word
-Joel
Unread 08-01-2003, 23:03
I'll beleive it when I see it...
I'm looking for the rule myself, but its an elusive beast....
heh and I'm supposed to be in charge of knowing all the rules for my team. We're doomed
Unread 08-01-2003, 23:05
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Do you think you would be allowed to lift the other robot for a purpose other than puting it on you? In other words, could you hold your opponent off the ground for the entire match?
Unread 08-01-2003, 23:07
not on CD enough...
you are allowed to pin a robot for ten seconds, so you'd probably only be allowed to hold them up for ten seconds, then you'd have to put them down and back up three feet until you could engage them again..
Unread 08-01-2003, 23:08
http://jive.ilearning.com/thread.jsp...t=30&trange=15
there's a partial answer, but its not too descriptive
Unread 08-01-2003, 23:10
Ah ha!
http://jive.ilearning.com/thread.jsp...t=45&trange=15
That one clearly states it... so holding a robot has no score bonus. I could've sworn woodie said differently at the kick-off, but maybe he was wrong there too.
Unread 08-01-2003, 23:14
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
I personally think having that as a main objective makes you a very limiting alliance partner. In fact, I think it unwise to even attempt as a main design.
First off, if you are able to surround a bot and have it's wheels be free spinning (so it can't drive off of you) then you will become top heavy (or side heavy.. depending on how you have it held). Going up the ramp has serious potential for tipping your bot. Consider that the opposing bot will be raised and also be ~120-130lbs which raises your center of gravity. If the robot is very tall, it raises it even more. Even has potential to qualify as an intentional damage (when the opponents bot is dropped/falls off).
With a sole purpose to disable another opponent, you no longer are able to be a big help on offense. Unless you plan on driving around pushing boxes with their bot on you.
Also consider that many teams will have some type of arm that they could swing. The forces from the arm(s) will almost surely tip you and you're opponent making the match 1 v 1.
Unread 08-01-2003, 23:17
D@ve's Avatar
D@ve D@ve is offline
Make it Happen
AKA: David Ferreira
FRC #0078 (Air Strike)
D@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of light
Send a message via AIM to D@ve
If some teams do chose to do this . i'd like to see it. being a different kinda robot then most usually makes you stand out form the rest. And thats what make First exiting.
and lets not even get into the trouble of lifting a robot that weighs just as much as yours does while keeping balance...
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
