Go to Post I'm 5'5", and I'm our team's drive coach. Our drivers are nearly always taller than me. In my case, it's not the driver's station that needs to be made of lexan...it's our drivers. - StephLee [more]
Unread 17-04-2012, 18:08
Bruce Meyer Bruce Meyer is offline
FRC #1023 (Bedford Express)
Bruce Meyer is on a distinguished road
Bedford Express 1023 Encoder for shooter
A few people stopped by our pit asking about robot sensors. They liked an encoder we are using this year for a few reasons:
- Easy surface mount
- Accepts shaft sizes 2mm through 8mm
- dip switch for resolution
- cost under $25
I said I'd post the info on CD, so here it is!
Digi-Key part 102-1307-ND (AMT102-v kit) is the encoder. 102-1503-ND is the pigtail connector. Check the spec sheet to match the color wires for connection to the cRIO digital side car.
And thanks to Digi-Key for the KOP voucher this year!
Unread 17-04-2012, 18:50
BX MARK's Avatar
BX MARK BX MARK is offline
AKA: Mark
FRC #3542 (S.P.E.E.D.)
BX MARK will become famous soon enoughBX MARK will become famous soon enough
Re: Bedford Express 1023 Encoder for shooter
No way, we use the same thing!
2011-2012 Team 3542 S.P.E.E.D.
2010/2011Bedford Express Captain
Unread 17-04-2012, 18:57
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Looks great!
Just a few questions:
How accurate was the encoder readout?
The specs indicate that the pinout is a standard 1x5 .1" header; can you confirm?
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 17-04-2012, 19:00
Originally Posted by Bruce Meyer View Post
For your shooter wheel application, do you use both channels of the encoder or just one? Do you use 1x or 2x or 4x decoding? and, do you grab the counts and divide by elapsed time, or do you use GetRate() (or GetPeriod() for single channel) ?
Unread 17-04-2012, 22:33
Debbie's Avatar
Debbie Debbie is offline
AKA: Debbie May
Debbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond repute
Hmmm... wonder why that is Mark? lol
FRC 1023 - Bedford Express - Coach, 2009 - present
FTC 160 - Dana Broncobytes Coach - 2007 - 2009
FLL - Dana Unicorns Coach - 2000 - 2006
Bedford Express Varsity Letter Video BX Facebook
Unread 18-04-2012, 07:20
BX MARK's Avatar
AKA: Mark
Our teams have a great mentor thats why!
Unread 19-04-2012, 07:28
Slijin: the second part number connects to the header so you only need to match the wire color for gnd, +5v,A, & B edges. That's what I did anyway.
Ether: It's been a bit since I've looked at the code, so I'll answer with specifics later. I've been following your excellent Bang Bang controller posts. We are currently using LabView PID (with Ki=Kd=0). In the pits last Sat. We borrowed an rpm reader from TORC and were reading roughly +/- 40. It will be interesting to do some post season testing.
All: if you search the part number at DigiKey there are links for the spec sheets and an installation video.
Unread 19-04-2012, 11:17
J@GMFlint's Avatar
J@GMFlint J@GMFlint is offline
FRC #1243 (Dragons)
J@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond repute
We've used the AMT's for several years now on our drivetrains. The resolution is configurable to your application and the pigtail cable is pretty robust compared to the smaller US Digital-type leads. We've found shaft alignment to be relatively more forgiving as well, but due care is still required.
One thing to note: The plastic shaft collar/size adapters can sometimes come loose, so we put a light knurl on the shaft whenever possible for insurance. In a pinch, a single piece of electrical tape around the shaft works fine as well.
14th Season Leading and Mentoring Great Students!!
FINALIST 2014 GLBRD- Thanks 5281 & 2145
Qtr-Finalist 2014 Bedford District
Qtr-Finalist 2014 Kettering District- (Which way was the robot s'posed to be facing...?!)
FINALIST 2011 Kettering District- God work 494 & 1684- great elim. debut Chimera's!
WINNER! 2010 West Michigan District- Awesome job 3357 & 2054!
WINNER! 2004 West Michigan Regional
2004 Rookie All-Star & Highest Rookie Seed Pittsburgh Rgnl; Rookie Inspiration & Highest Rookie Seed West Michigan Rgnl (3rd)
2007 Semi-Finalist MWR
2008 Finalist MWR - Thanks 111 & 1504 Judges Award MWR
2010 Semi-Finalist Kettering District - Thanks 1, & our friends 2337
