#16
Re: By the book: wifi-less scouting?
when 1126 tried to use internet-based scouting at FLR it was an absolute disaster, we constantly lost our wifi signal and we couldn't have all 6 scouters on at once, and then we had issues with being able to send our data to one common source. however, i don't recommend paper scouting, as it is very difficult to crunch numbers this way, and it tends to overall just be less reliable, because people don't feel as inclined to fill things out (my personal experience, coming from the kid that was walking around with a huge binder of scouting sheets at FLR)
#17
So does anyone know a way to set up a wireless network (completely local) that will not interfere with FMS (and vice versa)? Do we just run on a different frequency?
#18
If you read section 4.3.1 Robot Wireless Control in the rules, you will see that wireless networks are prohibited anyway.
Because of this rule, our team has setup a completely wired network using a Apache2 server running on a laptop and a router to connect to other laptops which scouts use. However, we ran into issues with getting power at our last regional and needed to fall back on our paper system. Last edited by slang800 : 20-03-2012 at 23:16. |
#19
If you really need to have a network connection for your scouting efforts, you will need to use 3G, 4G, or WiMAX networks. |
#21
There's always more than a few stray wifi hotspots around the arena. The rules only prohibit teams from setting them up, not from using these wifi hotspots. Also, last few years, I remember there were competition officials advertising these hotspots (which you had to pay for). I doubt the intention of the rules (or wording) is to prohibit people from using wireless at all times. |
#22
Based on the discussion in this thread, there is no Wifi provided by the venue at Champs. Is there power? Our server system is a desktop; will we be able to get power for it?
#24
What I saw 1319 do: They have a scouting cart (just two wheels on it, like a small unpowered Segway with a T-handle) that holds a robot battery, a power inverter, and a network switch. Don't know if you'd want to extend that to a desktop, but it's a thought.
#25
The intention of the rules prohibiting connections is to ensure that no wireless connections interfere with the FMS. Given the prevalence of apparent FMS issues this year, and a noted correlation between FMS issues and numerous open networks, it is likely that this will be enforced more strictly than ever. Quote:
If you do follow this method, just make sure you verify that your battery and inverter specs meet the demands of your desktop. |
