Go to Post The on-going debate on this thread is just because we care. - Steve Wherry [more]
  #46   Spotlight this post!
Unread 17-04-2012, 17:43
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: The FIRST Alliance - A whole new way to play
I like the overall OPR and DPR. Any chance of including rankings or doing it by event as well? And/or by auton, teleop, end game (Twitter-dependent)? Other cool OPRnet like features would be great, too--sched, or even selected matches. (OPRnet is fantastic, but I tend to do better with GUIs...)
Ok, I like OPR. Flawed as it is.
Also, any thought in including the team's standings & awards on each event page and/or an overall team page?
In elimination mode for an event, is there any particular reason that the teams listed in "Elimination Teams" are not hyperlinked?
  #47   Spotlight this post!
Unread 17-04-2012, 19:23
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Could you also include a paper explaining how you're calculating OPR and DPR? And on that note, could you include separate columns doing OPR by hoops/bridge?
It's still great though
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
  #48   Spotlight this post!
Unread 17-04-2012, 22:04
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
It isn't in the roadmap yet, but we're working on it now actually.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
  #49   Spotlight this post!
Unread 18-04-2012, 00:37
mobilegamer999 mobilegamer999 is offline
FRC #3357 (Comets)
mobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the rough
OPR and DPR are calculated as described below. This is the same way that they are calculated for OPRNet and all other opr programs.
Take all teams at an event, count this set as T.
Create a matrix which is TxT, so you end up with a column and row for every team. We will refer to this as M and will describe how many times a team plays another.
So if T was (1,5,9) the M would be
1 5 9
1 - - -
5 - - -
9 - - -
Also, make a matrix that is 1xT and this will be O and will contain sum of all points a team scored
and thirdly, made a matrix 1xT which will be called D, and will contain sum of all points scored against a team
Now, for every match at an event follow the next few steps of logic
1) Increment M[A,B], if A!=B, increment M[B,A]
2) do 1 with A = red 1, B = red 1
3) do 1 with A = red 1, B = red 2
4) do 1 with A = red 1, B = red 3
5) do 1 with A = red 2, B = red 2
6) do 1 with A = red 2, B = red 3
7) do 1 with A = red 3, B = red 3
8) 2-7 with blue instead of red
9) for all red teams, O[red 1-3] += red_score
10) for all red teams, D[red 1-3] += blue_score
11) for all blue teams, O[blue 1-3] += blue_score
12) for all blue teams, D[blue 1-3] += red_score
then take inv(M) * O, and you get OPR's
and take inv(M) * D, and you get DPR's
this write-up may be a bit flawed, but thats the general flow of how OPR's and DPR's are calculated.
Also, right now we do have OPR's and DPR's per-team per-event, but as of now, we don't really have a clean place to put those details. So the power-rankings page is just the highest average OPR/DPR.
  #50   Spotlight this post!
Unread 18-04-2012, 00:40
FRC #3357 (Comets)
Yes.....a VERY good reason......I forgot, its fixed now, thanks for the bug report.
  #51   Spotlight this post!
Unread 18-04-2012, 01:01
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Glitch in eliminations view: The X's cascade back. For example, the second alliance won the regional in the finals vs the first. The first alliance is listed as losing all previous matches in the diagram.
I really like where this website is going. While you're doing OPR, as someone above mentioned, Teleop OPR and Bridge OPR are really the only useful ones this year. While you're at it, CCWM is another measure of team performance.
  #52   Spotlight this post!
Unread 18-04-2012, 01:05
FRC #3357 (Comets)
I've never heard of CCWM, I'll look into it a bit.
Second, the way the X's work is showing how a team is eliminated, so instead of showing where they won up to and crossing them out there, it crosses them out over the whole thing as soon as they no longer make it to the next level. I was probably thinking of doing it more like the former, but probably just use green for all 'won' sections, then red where they were eliminated.
  #53   Spotlight this post!
Unread 18-04-2012, 09:38
Siri's Avatar
Dare greatly
If I recall correctly, CCWM = OPR - DPR. Calculated Contribution to Winning Margin (predictably) uses the team's alliances' winning margins rather than points score by (OPR) or on (DPR) them.
As far as how you're calculating OPR & DPR, this is actually a more loaded question than most years. I don't know if it's what slijin meant, but people are indeed calculating it differently this year, mostly by weighting Co-Op as bridge points. The conversations happened in a few of the different OPR threads, but the general gist was 5 or 10 points per CP.
  #54   Spotlight this post!
Unread 18-04-2012, 10:12
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
Looking at the eliminations page, what is the W-L-T column meant to represent? In its current implementation, it appears to be whether the blue alliance won, lost, or tied, but I guess I fail to see how this data is relevant.
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
  #55   Spotlight this post!
Unread 18-04-2012, 10:46
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
After seeing the robot picture feature, what if The FIRST alliance had a robot reveal video feature too? I know that people are asking for matches, but I think a reveal would be interesting and different.
Just an idea.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
  #56   Spotlight this post!
Unread 18-04-2012, 10:52
Andrew Lawrence
Posts: n/a
Just an idea.
I second that. There needs to be a place on the internet where all of the unveil videos are kept together, and it may as well be the FIRST Alliance.
  #57   Spotlight this post!
Unread 18-04-2012, 12:03
GGCO's Avatar
AKA: Grant
FRC #3357
Hmm... really interesting idea. We'll look into it.
The FIRST Alliance
COMETS Robotics
Website
  #58   Spotlight this post!
Unread 18-04-2012, 12:07
FRC #3357 (Comets)
Just an idea.
I really like this idea, we should have something up in the next day or two.
  #59   Spotlight this post!
Unread 18-04-2012, 14:15
FRC #3357 (Comets)
Okay, that went a little quicker than expected. You can now link any youtube video on TFA.
  #60   Spotlight this post!
Unread 18-04-2012, 14:27
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
I was wondering if the videos, or photos that are posted are moderated and how it would be possible to remove either a picture or video? And if this isnt possible if it would be able to make some moderators or allow users to remove team photos
