Re: T-shirt Cannon revolver seal
Hi, I am a part of the team that is creating our second t-shirt cannon for team 2073. We are currently designing on solidworks and started to realize some major problems. We are trying to figure out how to control the scuba tanks and the part that is needed as a solenoid. We would like to know how to control the scuba tanks high pressure. Thanks
YOu need a pressure regulator, as well as a large diameter solenoid valve. and probably a second storage tank, and another solenoid valve (at least that's how we did ours years ago)
I recommend a sprinkler valve, our T-shirt Cannon uses one.
I would not recommend a sprinkler valve, just because I've read threads suggesting the same and concerns about how safe it is.
We based off our T-Shirt cannon off of 254's Shockwave and like Squirrel mentioned Quote:
We have a gap of about half an inch (yes I know it's quite a bit) between the exhaust valve and the barrel but the maximum range is still about 200 feet. |
GRT808 Can you post some pictures.
Our revolver has been upgraded with a scuba tank as well. We have the scuba regulator fixed at 120 psi and have a second regulator (standard FRC regulator) that adjusts pressure into the accumulator tank at no more than 60 psi and we have a third regulator that adjusts pressure into a small accumulator tank that operates the modified 3/4 in gate valve we use to fire the contraption. Our revolver seals are spring loaded pvc on both sides of the revolver cylinder and only open up about 1/8 inch when firing. We get about, never measured it but probably about 100 ft at max elevation. We do have 10 shots though and the accumulator tank refills in less time than it takes to rotate another shot into place. Bruce |
Found it! Sorry it took so long. In the picture it looks a bit bad...but it works. Check it out on youtube sometime. (and in our chairman's video)
