Go to Post Some people use Autodesk, some SolidWorks, some Pro-E, but 772 rose to the call of an unconventional CAD language, Minecraft. - Walter Deitzler [more]
Unread 04-20-2012, 01:38 AM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Smart dashboard Camera Problem
Yes, you need to enable the anonymous preview feature on the camera. This is a separate feature than simply being able to view the live stream via the web admin interface without logging in.
I don't recall the exact submenu, but there is a checkbox for it in the web admin interface on the camera.
Once enabled, your SmartDashboard camera feed should start working.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 04-20-2012, 08:30 AM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Unfortunately, that option is already checked. I'll try to completely reset the camera to see if that fixes the issue.
Thanks!
Mike
Unread 04-30-2012, 12:19 AM
Software Mentor
AKA: Mike Anderson
Thanks!
Mike
Hmm... Well, it didn't fix the issues. And, based on polling around at the championships, we were not the only team to have these problems. Fortunately, I spoke with Brad Miller from WPI and it would appear that the Smart Dashboard is being reworked a bit to address these and other issues as well as adding a few new features. So, there's hope for next season at least.
Mike
