Go to Post "It is a guaranteed fact that at least one rookie team will name their robot 'Chuck Norris'." - Tim Arnold [more]
Unread 20-04-2012, 12:38
hiyou102's Avatar
hiyou102 hiyou102 is offline
hiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud of
Smart dashboard can't connect to camera.
Our team has recently started using a command based robot and along with smart dashboard. Our issue is that although the camera is configured properly and is set up to the IP 10.43.34.11 when we put this IP into the smart dashboard interface the camer module continued to say 'no connection'. Our camera is connected to the router and was configured with the tool that comes pre-installed on the Classmate.
Unread 20-04-2012, 12:54
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Smart dashboard can't connect to camera.
We started having the same problem when we moved off of the classmate and onto another computer. Guessing there is a setting on the computer that is blocking it.
Unread 20-04-2012, 12:55
SM987 SM987 is offline
AKA: Stephen McKinney
FRC #0987 (The High Rollers)
SM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond reputeSM987 has a reputation beyond repute
Does the camera connect to the default LabView dashboard? See if you can log into the camera in a browser. Double check to see that the "Enable Anonymous Viewing" box is selected in the users tab.
Attending:
2017 Utah Regional
2017 Las Vegas Regional
2017 FIRST Championship Houston
Team 987 - The Highrollers - Las Vegas, Nevada
Unread 20-04-2012, 13:06
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
We are using the smartdashboard.
All opinions are my own.
Unread 20-04-2012, 13:17
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Be sure to turn off your firewall. Another team we were helping at Queen City had some issues and it turned out the firewall was blocking the data.
-Hugh
Unread 20-04-2012, 13:45
For SmartDashboard viewing you need one more setting that the tool doesn't do for you. SM987 mentioned it.
Browse to the camera and go to:
Setup->System Options->Security->Users
click the box for Enable anonymous viewer login
Here's a screen shot of the page on the Axis M1011. It's similar on the older Axis 206 camera.
http://www.chiefdelphi.com/forums/at...9&d=1333830785
Unread 20-04-2012, 16:34
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
1) Make sure anonymous viewing is on
2) In SmartDashboard, set SmartDashboard to editable and double click on the camera, make sure that the ip-address is pointing to what you want.
