Go to Post this is a TEAM effort...teach them something. Who knows, with a little luck, you might just learn something yourself! - Nuttyman54 [more]
Unread 07-04-2012, 10:29
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Andymark Plaction wheels vs IFI wheels
Originally Posted by RufflesRidge View Post
A single drop of Loctite + any of the things you described above
Yeah, we have never had a problem with the bolts. (Well, sometimes they're really hard to undue (so nylocks are nice, too)...) The main complaints here seem to be about the polycarbonate shattering.
Unread 07-04-2012, 10:40
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Originally Posted by AlexH View Post
colsons are another option and are much more durable than ifi/andymark plaction wheels.
While I understand the thread is AM Plaction vs. IFI Wheels, for a dead axle wheel, I can not recommend Colson Performa wheels enough. I may sound like a broken record by now but... We have run them for the last two seasons and I don't intend to use any other wheel again unless absolutely mandatory. The cost to go to a Colson wheel is less than an AM or IFI, the hubs are available through West Cost Products.
Unread 21-04-2012, 00:17
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
How are AM performance wheels compared to IFI wheels?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 21-04-2012, 00:20
Andrew Lawrence
Posts: n/a
Although they are called "performance" wheels, they generally have the same advantages/disadvantages of plaction wheels. Though they can be used easier in a live axle setup than plaction/iFI wheels.
Unread 21-04-2012, 01:28
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
The performance wheels have noticeably more grip, partly due to lack of a draft from the molding that occurs in plasticon wheel manufacture, but also because the aluminum rim is not as large, and contacts the floor less than the plasticon retaining ring. I would go with performance wheels any day, as long as you keep to the 4 and 6 inch sizes they are not that much heavier or more expensive.
Unread 21-04-2012, 21:15
Gregor's Avatar
So would plaction wheels or IFI wheels combined with blue nitrile tread be an ideal combination?
<Since 2011
Unread 21-04-2012, 21:24
Andrew Lawrence
Posts: n/a
Really? That's pretty cool. Didn't know that. Thanks!
Depends on how you use them. The wider the wheel, the harder it is to turn. With blue nitrile you have a lot of grip on the carpet, meaning a lot of turning scrub when you try and turn. So unless you're really experienced with them, you may find trouble turning with blue nitrile and wider IFI wheels, compared to the thinner plaction/performance wheels.
I've never had experience with the 1" width IFI wheels, so I can't say anything about them, but I've had experience with both wider ones, and plactions.
Unread 21-04-2012, 21:26
FRC #1836 (MilkenKnights)
Originally Posted by Chris Fultz View Post
If you do some testing you should see no difference between 1" and 2" wide. You are providing a bigger area but with the same total downward force (weight of robot) spreading over that larger area you don't gain. Traction is a tricky thing and some controlled tests can be cool.
To the op, we have used and had good success with all. We are using the am 4" performance wheels right now with blue tread from mcmaster. It is a little gripper than am or IFI tread but only comes in wide sizes so it has to be cut (I think 3" is the narrowest)
While this is true, I have heard that the 2 in thick wheels wear better.
Unread 22-04-2012, 01:52
AKA: Isaak
Team Role: CAD
During our season this year we found that a lot of a robots ability to push other robots actually comes from bumper placement. Because our robot was designed without the requirement of crossing the bump, our bumpers were lower than most other robots by about 1.5 inches. When we ran up against them our bumpers wedged slightly underneath theirs as well as pushed their robot up onto ours due to torque generated on the robot body along the axis parallel to the interacting bumpers and the floor, robbing them of grip in this way allowed us to easily push robots with similar traction characteristics to ours. I think that this might cause some miss-information about the effectiveness of smaller wheels, smaller wheels usually lead to lower bumpers which leads to better pushing power in matches.
TLDR: If two robots were exactly the same, but one had bumpers 1.5 inches lower, it would be able to push the other.
Unread 22-04-2012, 02:01
Yes. That is the reasoning for some of the very unique bumpers we have seen this year.
