New Feature - HyperRules
Looking for an easy way to link to a specific rule? I have just completed work on the HyperRules web site, which holds the complete set of rules from FIRST, including team updates when they are released. The complete system can be seen at http://www.creationsandkeepsakes.com/hyperrules/, but if you just want to link to a specific rule, Brandon has graciously added the following vB Code tag: [rule]
To use this to link to a specific rule, use the following syntax: PHP Code:
Unfortunately, at this time, you can only link to rules in the following sections using this format: -Robot Rules Section 4 (K, M, C sections) -Game Rules Section 9 (S, GM, SC, V, DA, DQ, T sections) Functionality to link to any other section will be added in the near future. Enjoy! [EDIT]Thanks to Katie for pointing out that vBulletin put the comma after the URL inside the URL rather than outside...I fixed it here as well...[/EDIT] Last edited by Nate Smith : 09-01-2003 at 10:33. |
a test
This rule (GM19) clearly shows that the human players in Dave Lavery's animation are rebels and should be dealt with accordingly.
Sorry, just had to try it out. Last edited by Kris Verdeyen : 09-01-2003 at 17:27. |
Great job Nate
.Now if only there's a search in the website. Then anyone can look up anything in the rules. |
- Somebody will have fun building a db from a pdf! |
![]() @Ken: There's a 'search' box on there, too. Doesn't seem to return anything (unless I searched for something too vauge). |
#7
The search(yes Ken, there is one) is currently using a simple SQL LIKE clause in the query. I just implemented a notification system where it will log any searches which return zero results. I'll be keeping an eye on that log to see if I can notice a definite problem with the search logic, and adjust it as needed.
And no, I didn't type it all, but let's just say I've done a LOT of copying and pasting over the past few days... [EDIT] The search system has been upgraded. It should now be working again. [/EDIT] Last edited by Nate Smith : 10-01-2003 at 11:03. |
#8
Is there any way to make the link open a new window, like the normal links do? I was recently typing a response to a question on pneumatics, embeded the appropriate rule, and clicked "preview post". When I clicked the link to make sure I had chosen the correct rule, it openend in the same window, destroying everything I had typed.
Nate Smith: Very cool, and very useful. Thanks for all the work! |
#9
New Feature: Discussion
Courtesy of Chief Delphi Forums, Hyperrules now has a "Discuss This Rule" option. Simply click the link when you're looking at the rule you want to talk about, and you will either start the new thread, or join the discussion already in place. Check it out!
#11
Nate, Brandon: You guys rule! HyperRules is so handy - Thank you!!!
![]() - Katie |
| The Return of HyperRules | Nate Smith | General Forum | 2 | 05-09-2003 10:31 |
| HyperRules Returns! | Nate Smith | Announcements | 0 | 04-02-2003 12:19 |
| Victor braking feature | MattB703 | Electrical | 12 | 21-06-2002 07:26 |
| feature suggestions | rbayer | Programming | 4 | 04-06-2002 21:54 |
| best new feature? | Joe Ross | CD Forum Support | 2 | 01-06-2001 18:57 |
