Go to Post Your drivetrain is THE most important system on your robot. Don't rob from it. - Monochron [more]
Unread 21-04-2012, 15:24
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
WCD-Style Belly Pan Weight
After cadding up a 1/8" 6061 "WCD-style" belly pan, Inventor calculated its weight to be around 5.2 lbs. Would anybody consider this to be an accurate measurement? Assuming it has a diamond/cross hatch pattern similar to the ones displayed in this thread and encompasses the entire bottom part of the drive base.
Strictly in terms of weight, 5.2 lbs is around a pound lighter than the 1/4" unpocketed polycarbonate sheet that we used this year and had no problems with.
Unread 21-04-2012, 15:44
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: WCD-Style Belly Pan Weight
Sounds reasonably correct. My team used a 1/16" belly pan (5052 aluminum) this year with no pocketing and it weighed 5 pounds. Assuming you're using something like 6061, 6063, 5052 depending on the size and how much pocketing, 5.2lbs is reasonable for all of those.
Unread 21-04-2012, 15:53
Borobo Borobo is offline
AKA: Patrick
FRC #0159 (Alpine Robotics)
Team Role: CAD
Borobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really nice
What our team has used for the last few years is a type of plastic extrusion called veralite it's really light, but if you mount it so that the grain of the plastic cells is right for the load, it can be way more rigid than polycarbonate sheets. for example, out bellypan this year for our WCD was about .3 pounds. it's also easy to drill holes in for zipties and other wire routing hardware.
Unread 21-04-2012, 17:14
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
We did 1/8" 5052 on a prototype with a ton of pocketing, and it came to 4.5lbs or 5lbs. One of our main reasons for the bellypan is keeping the frame stiffer in torsion. Have you found any advantages to 1/16", especially if the weight is about the same as pocketed 1/8"?
Unread 21-04-2012, 20:29
FRC #1836 (MilkenKnights)
Also, remember that a belly pan the one of the closest things to the ground on any robot. This helps lower you CG, which is really important in most games, and very important on any 6 wd bot. Furthermore, with lightening, it allows you secure attachment of electronics, and stiffens the whole frame. Therefor, it is worth the weight to invest in a bellypan.
Unread 22-04-2012, 00:40
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
i havent seen a west coast drive bot with this but i'd think polygal would work a bottom pan.
Unread 22-04-2012, 01:08
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Our belly pan this year on our 2012 robot is ~2.5 lbs. We could've made it a little lighter. We added/left material where we thought we would need it for mounts/stingers in the feature.
-RC
R.C.
MadTown Robotics Team 1323
Unread 22-04-2012, 01:14
-RC
What material is it?
Unread 22-04-2012, 01:21
Fairly positive its just 1/8" 6061.
Unread 22-04-2012, 02:29
R.C.'s Avatar
Aluminum - 6061 - 1/8" Thick
-RC
R.C.
Unread 22-04-2012, 02:47
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
We went with wood after our aluminum bellypan (much like the one shown above) turned out to be about 5 pounds, which put us overweight. The wood performed great and was much lighter than the metal after we gave a freshman a two inch hole saw. In the end it weighed between 2-3 pounds.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 22-04-2012, 08:59
Gdeaver Gdeaver is offline
FRC #1640
This has come up many times in the past and I always respond with make a composite belly pan. From a mentors view making the belly pan - electronics board from composites is an excellent way to introduce students to the mystical world of composite construction. What our team does is take a 1/4 " , 4mm or 6mm piece of birch ply wood and laminate both sides with 5.7 OZ plain weave carbon fiber using vacuum bagging methods. It's not that hard and is doable by most teams. 11 of our student got hands on experience this year. All though keeping the students focused and neat, not making a gooey mess can be quite mentally draining. The end product is a wonderful material. I can provide some link if needed or search youtube, there are some good videos on it.
Unread 22-04-2012, 10:56
sgreco's Avatar
AKA: Steven Greco
FRC #2079
We use 1/16 primarily because that's what our metal shop has standard in stock. So it's cheaper (actually free) for us to use 1/16, and the turnaround time is faster. We also typically put a few flanges on the sides to make the pan sit nicely in the frame with lateral support.
But you're right, 1/8 acts to stiffen the frame much more than 1/16 does, for us it's just a matter of what resources are most readily available.
Unread 22-04-2012, 20:20
Not a kebab
-RC
Wow, our cheesing patterns must be very different then...
Unread 23-04-2012, 00:20
R.C.'s Avatar
When you get a chance, send me a solidworks file.
I'll take a look at it for ya!
-RC
R.C.
