Re: Plactions treads and rubbing alchohol
The colored part, the "bridge deck" is HDPE. On top of that is clear polycarbonate, the "bridge surface".
If you want to add grip I would try to remove the effect of the molding draft from the plasticons. Bowing the tread out so that the MIDDLE of the wheel rather than the outer edges has the largest diameter will greatly increase grip.
Do some research on the materials. There is a very specific reason the the Buna-N-Rubber, Nitrile and Natural rubber most teams use does not work as well on the bridge polycarb.
For the teams that have used the Blue Nitrile tread, how do you cut the tread down to a width that's manageable? I see 3" ad the minimum width, and I'm pretty sure 3" will be too much for manageable turning.
Scissors, a knife, sometimes a saw blade....just about anything cuts it. Just find the width you want, measure (twice), mark the area, and cut.
When I was on teams who used this material we always marked the back side of it and cut it tread side down on a bandsaw.
#7
The few times that I've cut Blue Nitrile, I've used a bandsaw as well. I've found that the only way to get a remotely straight cut was to clam a piece of angle (or other material) to the table of the saw to act as a guide.
#8
I was hoping to avoid using a bandsaw... My shaky fingers often mess up cuts, and those burs really are annoying. How much more advantage does Blue Nitrile have over roughtop or Colson?
#9
We often use a box cutter or razor blade (along with a clamped-down straight edge) to cut our tread to length and width. It isn't too difficult.
Based on qualitative observations (and a few quantitative experiments), blue nitrile outgrips Colson wheels on carpet (particular with wide, small diameter wheels), but on HDPE and polycarbonate surfaces, the Colsons grip a bit better. Adding custom tread patterns to the Colsons supposedly closes the gap with roughtop tread on carpet. |
#10
If you don't think it's worth the hassle, just use roughtop/colsons. You're not going to loose any needed power. |
#11
Of course, the only thing preventing me from using colsons is the time and financial cost of making your own live axle hubs for them.
#13
You want a simple live axle plug for the colsons 1.5" wide, buy a piece of 1.25" OD diameter aluminum rod, turn down to 1.2" inches OD, drill thru and broach for whatever you want to drive, and cut to 1 5/8" long. Press in, and drive. Or just wait a few months, I hear that WCP will be selling live axle plugs in the future. |
