Go to Post Ahhh... the beauty of an exponential series... - dtengineering [more]
Unread 20-04-2012, 01:30
FRC #1836 (MilkenKnights)
6/8 Wheel Extra Features
This year, we really like our 6 wheel drive. We wan't to improve it for next year, including increasing performance in general, and by maybe adding some extra features.We had some questions about these features, if anyone has used these before, including:
2 in thich Wheels
  • Is there a notable increase in turning scrub?
  • Is the increased traction noticable? In what ways?
  • Have you found that it improves your defensive/offensive performance?
Drop down casters
(I heard that 987 has done this previously. Correct/incorrect?)
  • How effective is it at getting out of t-bone pins?
Drop Down Outer Wheels
(I heard that 469 has used this previously. Correct/incorrect?)
  • Have you found that it imroves your offensive/defensive performance?
Obviously, in qual matches, these would most likely have little to no effect on performance. But in elims, it seems like there could be a significant improvement in performance.
Unread 20-04-2012, 02:10
Chad987 Chad987 is offline
It's not enough.
AKA: Chad Pesquera
FRC #0987
Chad987 will become famous soon enoughChad987 will become famous soon enough
Re: 6/8 Wheel Extra Features
Originally Posted by MICHAELABICK View Post
Drop down casters
Yes we did. We used it quite a few times last year, extremely useful.
We would have one this year, if we had the weight.
Unread 20-04-2012, 07:18
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
2 in thich Wheels
Drop down casters
2 inch wide wheels don't make as big a difference as tread material, and they can make turning a little screwy.
We used drop down omnis instead of casters and the drivers loved them. They did help against defense.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 20-04-2012, 07:24
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
What I quoted above is one of the most important things a team can do. Setting a baseline, and improving from it each year.
On FRC2168, we did the same thing this year, and intend to improve again on it for next year.
Things we improved on from 2011-2012:
- Moved from a 6WD to a 8WD to gain some stability (and to go over the barrier)
- Designing for Center to Center distance between axles to have exact chain or belt length
- Designing the tensioners in as standoffs as well (A 1" nylon rod with an off center thru hole, rotate to add tension)
- We continue to use 1.5" wide Colson Performa wheels with a WCP hub and dead axles as we like the grip and the wear properties
Things we are looking to improve/add in the future:
- An Integrated braking system
- Belt Drive
- Reduce weight
- Increase efficiency (less gear reduction/better gearing selection)
- Attempt to decrease wheel diameter
- Improve packaging/modularity
About you question in wheel width, this topic has been discussed a number of times, with different answers. For us we have noticed that while our traction seems to be about the same, our tread seems to wear better with a wider contact patch. It's for this reason, and the amount of space they take up that we settled on using 1.5" wide wheels.
There are a ton of options out there in terms of wheel options, and even more for tread material. I strongly suggest exploring them.
Unread 20-04-2012, 10:37
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Drop down casters
I am confused on this. Can someone explain why having drop down casters would help with defense? Also, what do Drop Down Outer Wheels provide? Some pictures would help if possible.
Thanks.
-T
Unread 20-04-2012, 10:43
Thanks.
It changes your center of rotation allows you to spin about 2 outer wheels rather than the middle wheels. This prevents you from getting t-boned by allowing you to spin out of it.
Thank-you 294 & 67
Unread 20-04-2012, 10:48
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Thanks.
Traditional Skid Steer Drive trains are very susceptible to 'T-Bone'* pins. Because Most Skid Steers rotate around their center, or somewhere close to it, they cannot simply spin out of the pin - if you draw a simple sketch, you'll see that while you're rotating one end of your robot away from the defender, you're also rotating a side into the machine.
Dropping a caster/omni-wheel/skid on one end helps to move the pivot point of the drive to the opposite end, which allows the robot to simply spin out of the pin.
*T-Bone Pins usually refer to an instance where a robot is hit perpendicular to it's drive train's motion - these usually happen on open field, essentially pinning a robot without needing a wall/object.
-Dustin Benedict
Unread 20-04-2012, 10:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I'll make a plug for WCD ("West Coast Drive") here. The concept of the frame setup, wheel blocks, live axles, cantilevered wheels and tensionless chains all cobmine to make it a great, versatile drive setup. Our team will do this next year since we proof-of-concepted the first sliding block in March. It took 2 hours to make the block on a manual mill, but we feel confident we can get that time down.
WCD itself isn't the answer to everything related to drive train -- yet it is the one "baseline" drive train that allows for the most design adjustments (# of wheels, wheel diameters, wheel types, tread types, which gearbox, etc) in the least amount of time. Adding extra features (like a drop-down caster/omni) is very easy as well.
GitHub
Unread 21-04-2012, 07:22
Are you referring to turing scrub? Has anyone else used 1.5 in wheels with success?
By dropping your outer wheels, you theoretically are able to gain more traction when you are trying to push through defense or stop offense.
Unread 21-04-2012, 08:27
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Some tips learned from our drive-train this year:
Hollow tubes make for great axles, These were tapped so that there were no collars on any of the drive axles, it also saved a ton of weight, we used .495 OD with roughly .1 walls.
Track width, our 6 inch performance wheels were less than .125 from the edge of the 28 inches, it made turning much more forceful.
Maximizing traction, blue tread from Master on 6 inch performance wheels has a LOT of grip.
Choosing the proper gear ratio, our high and low gears were 16.6 and 6.7 ft/s this is NOT traction limited in low gear, enabling us to push robots with lower gear ratios when they broke traction due to overzealous driving.
Drop down casters sound interesting, our driver never got stuck on other robots, but if he ever got close/parallel to a wall it was difficultly to quickly get UN-stuck.
Unread 21-04-2012, 10:31
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
If you look several posts higher you will find that someone mentioned 1.5in wheels.
Unread 21-04-2012, 17:59
JesseK's Avatar
FRC #1885 (ILITE)
Exercise caution in future years and apply the material for the year rather than using the "we always do it this way" way of thought. I'd be concerned that the outer axles would bend if it came off the bridge or bump incorrectly. Did you do any simulation or calculations to figure out the tensile stresses your axle could hold?
On a flat or predictable field like 2005, 2006, 2007, 2008, 2009, & 2011 this isn't a concern.
GitHub
Unread 21-04-2012, 23:44
I saw. I was just wondering if the consensus was that 1.5 in wheels were the way to go.
Unread 22-04-2012, 00:03
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
As far as the width of the wheel, we on 973 noticed a big difference in traction with 2" wide wheels vs traditional 1" wide wheels.
In 2011 we used a wcd with 4" diameter, 2" wide weels, with a 3/16" center drop. The combination worked great. The drivetrain allowed us to switch from strict offensive play to strict defensive play with the ability to push every robot we came in contact with. Check out the cad for Titan in my signature. If you like what you see feel free to use our design(s) and pm us if you have any questions.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 22-04-2012, 00:12
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
In 2011 team 33 had an 8wd with the back wheels able to articulate up/down. When they were down it picked up the back of the robot enough to lift the inner 4 wheels off the ground making it very difficult to turn us. When they were lifted up we were an 8wd that could turn on a dime.
Just adding to the mixing pot.
Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
