Go to Post If I was a balding man, and Dean Kamen signed MY head, I'd immediately make my way to the nearest tattoo parlor and have them make it a permanent fixture. I wouldn't have washed it off! Just saying. - Carolyn_Grace [more]
Unread 21-04-2012, 19:55
Michael_Lee Michael_Lee is offline
FRC #2976
Michael_Lee is an unknown quantity at this point
Multithreading and locking?
According to the documentation, "Task.h" provides a way to do multithreading on the robot. I wanted to try running my camera processing code on a separate thread and ping back on it periodically to grab the latest set of data it produces.
I'm pretty new to multithreading, but as best as I can tell, I need to lock a variable or something before I read/write to it to make sure things don't go haywire. However, I don't know how to lock a variable or otherwise communicate between a thread and the main program.
How would I accomplish this? If possible, could somebody point to some example code that does something similar so I can use it for reference?
Unread 21-04-2012, 21:25
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Multithreading and locking?
Google around for "VxWorks semaphore", and have a look at the SEM_ID data structure.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 21-04-2012, 22:06
Skinkworks Skinkworks is offline
The guy with the Fez
FRC #1302 (Team Lionheart)
Skinkworks is on a distinguished road
Just use global variables. Don't tell anyone (I know it's bad), but our team does't use any lock/semaphore-type structures, and we've never had a problem. Then again, the data shared between the threads is only a float and a string.
Yes, I am the same person from the FTC forum.
FTC #248 (2009-2013): Fatal Error, Programmer, Driver, and Builder.
FRC #3142 (2009-2012): Aperture, Build, Design, and Programming Leaders.
FRC #1302 (2012-2013): Lionheart, Build Captain.
ZRHS #89 (2011-2013): Team Kühlschrank, strategist and programmer.
ZRAC #40 (2012): Catcher in the Skye, programmer.
FLL #3149 #15193 (2011-2013): Mentor.
ISR 12: Umptysquatch 6, Designer, and Builder.
FRC #???? (2013-????) Mentor.
FTC #???? (2013-????) Mentor.
FLL #????? (2013-?????) Mentor.
11 seasons of FIRST in 6 years. I wish I could've done more.
Unread 21-04-2012, 22:14
Zera's Law: Once you realize that something bad can happen, it will.
Unread 22-04-2012, 02:56
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
One example worth looking at is the PIDController. It spawns a task which updates every 50ms from the PIDInput and writes its results to PIDWrite. That will serve as a good example. But if there's a lack of clarity as to what you're really trying to do, here's "it" in a nutshell. Since you have two tasks running at the same time, one must be careful to not wind up modifying something while it is being read by the other task. The lock basically says that the other task cannot get their lock until you unlock on the other one. One must also be careful to program in a manner where you always give up a lock that you've taken - or else the other thread will be forever waiting to gain the lock which you never give up.... and similarly, if you take a lock, you have to be careful to make sure you don't accidentally call a function which tries to take the lock a 2nd time which would result in the same deadlock situation.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 22-04-2012, 12:03
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
I can attest to that. As soon as I took a second look at our code I realized that we'd had static initialization order issues, and sure enough, a few days later it segfaulted...
The AxisCamera code also has some locking that you can look at. We also wrapped it a little in our code: https://github.com/rbmj/612-code/blo...ion_thread.cpp
Unread 13-09-2012, 19:32
jacob9706 jacob9706 is offline
AKA: Jacob Ebey
FRC #3574 (High Tekerz)
jacob9706 is on a distinguished road
I was looking through your code and do you realize you can use namespaces?
so for example right after your includes you would put something like this...
using namespace cv;
using namespace std;
Now that you have that instead of doing something like
std::cout << cv:oint(10,10) << std::endl;
You can now do this
cout << Point(10,10) << endl;
Just something I thought I would share with everyone.
* Team 3574 Alumni
* 2011 - Highest Seeded Rookie
* 2011 - Rookie All-Star
* 2012 - Engineering Inspiration
* 2012 - Olympic Deans List Winner
* 2013 - Engineering Inspiration
* 2013 - Judges Award (For unique circular robot and the way the team works together.)
Unread 12-02-2015, 21:17
pensono pensono is offline
FRC #5495
pensono is an unknown quantity at this point
As long as you only have one writer thread, you won't run into any problems.
Unread 12-02-2015, 21:25
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Very true. Arguing this very thing at work at the moment. Any context switch were writing can only occur in one of the context events then you do not need to lock it to protect it from the reader/writer problem.
Unread 12-02-2015, 21:55
That depends on the behavior of the scheduler, and what the "writer" thread is writing to...
Unread 12-02-2015, 23:33
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
That depends on the variable. Try to manipulate a linked list without mutual exclusion and you are toast. Using a global double on a 32-bit machine might cause you trouble. If the global variable is simply an integer or a float and there is only one writer you should be ok.
Unread 12-02-2015, 23:35
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
The kernel we are using has all the RT extensions enabled so they could be in trouble.
Unread 18-02-2015, 12:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
If you're not conscientious about read-once in a separate task, you can cause yourself problems again where obj.Value = 57 at the start of a function and obj.Value = 118 by the end, despite you not writing anything to it.
Unread 03-08-2015, 12:10
knuckleduster knuckleduster is offline
AKA: Jack Manning
FRC #0058 (The Riot Crew)
knuckleduster is an unknown quantity at this point
using namespace cv;
Actually, it isn't really considered good practice to use namespaces, when you start using multiple libraries with similarly named functions, it can get hectic, and its just better to get into the habit of not using them if possible.
