Go to Post If enough students "get it," the team will begin to. And if enough students "get it," the smart ones will seek out all the extra help they can get. That's how I found Chiefdelphi... - Joe G. [more]
  #46   Spotlight this post!
Unread 22-04-2012, 19:18
Andrew Lawrence
Posts: n/a
Re: pic: FRC971 Spartan Robotics Presents: Renegade
Originally Posted by Siri View Post
Awesome shooting! How do you like the steering wheel for driving control? And is it just the wheel or are the other buttons/pedals/something involved?
Same question. To add on, do you feel there are any advantages to using the steering wheel controller? (User intuitiveness, just feels easier/right to use, etc?)
  #47   Spotlight this post!
Unread 22-04-2012, 19:42
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Austin can give a more accurate answer than I, but I believe we are running a version of "Cheesy Drive"
At high speeds, your rate of turn is very sensitive to small disturbances in drive side speeds, so holding a good line with tank sticks gets increasingly difficult as your drive speed goes up. By letting the computer take care of the exact speeds and feeding the system a turning radius and speed, high speed control becomes much easier. It also allows you to scale the steering response based on your throttle level, although I don't know if we do that or not.
The quick-turn button allows a more traditional steering scheme for in-place turns. We've been using a steering wheel setup since 2006 and it's served us really well. It's just the wheel and a joystick for throttle control, as Jared surmised.
  #48   Spotlight this post!
Unread 22-04-2012, 19:45
Andrew Lawrence
Posts: n/a
Thanks. Just for reference, do you know which steering wheel controller you use?
  #49   Spotlight this post!
Unread 22-04-2012, 20:19
JV2073's Avatar
JV2073 JV2073 is offline
FRC #2073 (EagleForce)
JV2073 has a spectacular aura aboutJV2073 has a spectacular aura aboutJV2073 has a spectacular aura about
Good Job at the Sacrmento and SV Regionals. You were amazing and we hope to see you in go far in national.
-Best of luck team 2073
  #50   Spotlight this post!
Unread 22-04-2012, 20:49
kevincrispie's Avatar
kevincrispie kevincrispie is offline
kevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to behold
I believe the one we are using at the moment is a Ferrari Thrustmaster wheel. We've used a few different ones in the past, but they weren't as robust. The wheel needs to be auto-centering one way or another, whether that be by design or stringing surgical tubing inside the wheel. However, its much better to have it bought as auto-centering. It less work to convert over.
"If you want to build robots, you're going to have to break a few small appliances"
