Go to Post I believe youth is contagious. I want to catch as much as I can! - Al Skierkiewicz [more]
Unread 08-01-2003, 16:23
Justin's Avatar
Justin Justin is offline
Never Forget FIRST 1992-2000
Justin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant future
Send a message via AIM to Justin
Thoughts...King of the Hill
Hi Everyone,
I am curious, and not behalf on any one team, what people's analysis of the king of the hill strategy is. What does it gain you? Would you need to control the ramp the entire time? I'm curious what people think, if they have the time to comment on such a strategy. My own personal feelings it that it ties you to the ramp the entire match and severely limits offensive potnetial.
-Justin
Rookie Year: 1996 (Hexagon Havoc)
Robots: Hexcalibur (96), Blue Dragon (97), El-e-Vador (98), Astrobot 2000 (99), Last Chance (2000)
Unread 08-01-2003, 16:42
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
I'd agree with your assesment overall. A Hing of the Hill doesn't necessarly have to sit there for the entire match... I certainly wouldn't suggest buidling a bully-bot incapable of dealing with scoring situations and adapting. That being said, it could thwart a lot of opponents if you can really stay there for the entire match. Don't expect a ton of QPs, and be prepared for some serious stress if you do it.
Unread 08-01-2003, 20:24
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
My personal favorite is the King of the Hill strategy. However, it does have some obvious flaws, such as the fact that your opponents are trapped on your side and your allies are trapped on your opponents side, assuming you lack a gate mechanism.
I believe that it can be made to work, but the question is, is the trade off worth it? That remains to be seen, probably until the matches.
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 08-01-2003, 20:29
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
I agree with you, but I also believe that the 25 points will motivate many teams to try for it - some may take the entire 2 minutes to do it, while others will play the field and then do the mad dash at the end technique. In my humble opinion - the match es will be decided in the first 15 seconds and the last 15 seconds. But - what do i know I haven't witnessed a single match yet.
Unread 08-01-2003, 21:05
DarkRedDragon's Avatar
DarkRedDragon DarkRedDragon is offline
#0341 (Miss Daisy, and dang proud of it!)
Location: Im from Blue bell, but the team officaily is from ambler
DarkRedDragon is an unknown quantity at this point
Send a message via ICQ to DarkRedDragon Send a message via AIM to DarkRedDragon
the king of the hill part will get interesting. the polycarbonate ground has zero friction, so sliding will happen. The only way to stay up is to keep moving. Wither that or use suction cups and afixiate your bot to the floor. I have an basic out line if you would like it about the suction cup idea. i want to know what strats you guys have for surviving the chaos!
The air is what I yern for, infinite space and yet infinite restrictions. To master the sky is to break out of the mold and to break the rules!
Have you ever looked to the sky on a perfectly clear night, and see that we are only a spec of dust in this great universe?
1) Team 341 Galileo division champions
2) Team 341 won the Entrepreneurship award (I had a big part in that)
3)Had one great time!
Unread 08-01-2003, 21:26
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
First nothing has zero friction, second diffrent hardness of rubber comes diffrent amounts of slippage, with the hard wheelchair wheels on the top of the HDPE they slide like mad, but with a softer rubber and alot of surface area, I belive that you could some how lift your bot on it and never be pushed around, ever. Thats the type of bot that is going to win king of the hill
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 08-01-2003, 21:42
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
There's more to it than friction...
(and I'm not talking about suction cups - they slide too easily)
-Joel
Unread 08-01-2003, 21:44
-Joel
not nessacarily, when supported correctly, they take alot of effort to slide.
Unread 08-01-2003, 22:45
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
With large extensions, a robot could potentially block the whole ramp, not limited by the 36x30 starting size.
Also, although the traction on top will be bad, the traction on the ramp is bad as well, and may be worse, as there is much less surface area.
Unread 08-01-2003, 23:05
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
yes, bullying the ramp will be crucial, i mean, how do u win if u are not a "low rider"?
Bad
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 08-01-2003, 23:08
Gope Gope is offline
#0016 (Bomb Squad)
Gope is on a distinguished road
Suction Cups = bad
suction cups, if done properly, could almost garentee an immovable robot.
However, this stuff is very easy to scratch, and it WILL be scrateched and all it takes is one shallow scratch and your cups don't seal...muhahahahaha
College and its wonders. First year and alot of other FIRSTs.
Unread 09-01-2003, 08:50
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Traction has about zero to do with surface area. This is even more true when on a completely flat and smooth surface. Remember, that traction is gained by friction. And, the formula for friction is F=uN where u is the frictional constant which is determined by the materials involved and N is the normal force. There's nothing in there about surface area. You do not need a lot of surface area to have good traction. In fact, it may actually be harmful (see one of the whitepapers about it).
Matt
Unread 09-01-2003, 13:58
Doug's Avatar
Doug Doug is offline
#0122 (Nasa Knights)
Doug is an unknown quantity at this point
uh oh i can smell the whole wheel width vs traction debate coming
yeah sorry i dont beleive in punctuation
122's stacking machine
Unread 10-01-2003, 09:52
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Suction Cups = bad
Yep, I just tested that about an hour ago.
Suction cups + *tiny* scratch on surface = no suction
Suction cups + tiny scratch + vacuum = barely any suction
Do as you will.
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 10-01-2003, 10:01
MKriegsfeld MKriegsfeld is offline
MKriegsfeld is an unknown quantity at this point
just F.Y.I.
The rules strictly state that there is NO use of any kind of vacume on the robot for any purpose. Also, you can't get a rubber that is too soft or otherwise it will get destroyed going up the mesh ramp.
991 "The Dukes"
Which Robot Do You Think should be King Of The Hill mtaman02 General Forum 58 14-04-2003 12:35
pic: 157 and 236 King of the Hill in the finals CD47-Bot Extra Discussion 3 16-03-2003 13:03
King Of The Hill And Others.... Alex Cormier General Forum 18 12-03-2003 09:11
King of the Hill Rusted_Grail Rules/Strategy 7 07-01-2003 14:40
DDR (?) on King of the Hill Elgin Clock Chit-Chat 13 14-05-2002 14:52
