Go to Post Innovating for the sake of innovating, reinventing the wheel is probably the second biggest pitfall you can fall into when designing an FRC robot, if the wheel is already a very optimized, good solution. - Chris is me [more]
Unread 23-04-2012, 09:42
Andrew Lawrence
Posts: n/a
Re: Plactions treads and rubbing alchohol
Originally Posted by Wing View Post
I was hoping to avoid using a bandsaw... My shaky fingers often mess up cuts, and those burs really are annoying. How much more advantage does Blue Nitrile have over roughtop or Colson?
I hear it's pretty grippy, and wears really well....but that's it. If you get into a pushing match with roughtops vs. nitrile, both with similar gearboxes/speeds, you're not going to find one will be drastically better than the other.
If you don't think it's worth the hassle, just use roughtop/colsons. You're not going to loose any needed power.
