Go to Post One of these years, the game piece will be an actual red herring. - Taylor [more]
Unread 23-04-2012, 08:55
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Plactions treads and rubbing alchohol
Originally Posted by Wing View Post
For the teams that have used the Blue Nitrile tread, how do you cut the tread down to a width that's manageable? I see 3" ad the minimum width, and I'm pretty sure 3" will be too much for manageable turning.
When I was on teams who used this material we always marked the back side of it and cut it tread side down on a bandsaw.
Unread 23-04-2012, 09:01
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
The few times that I've cut Blue Nitrile, I've used a bandsaw as well. I've found that the only way to get a remotely straight cut was to clam a piece of angle (or other material) to the table of the saw to act as a guide.
-Dustin Benedict
Unread 23-04-2012, 09:35
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
I was hoping to avoid using a bandsaw... My shaky fingers often mess up cuts, and those burs really are annoying. How much more advantage does Blue Nitrile have over roughtop or Colson?
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 23-04-2012, 09:38
Jared Russell's Avatar
Taking a year (mostly) off
We often use a box cutter or razor blade (along with a clamped-down straight edge) to cut our tread to length and width. It isn't too difficult.
Based on qualitative observations (and a few quantitative experiments), blue nitrile outgrips Colson wheels on carpet (particular with wide, small diameter wheels), but on HDPE and polycarbonate surfaces, the Colsons grip a bit better. Adding custom tread patterns to the Colsons supposedly closes the gap with roughtop tread on carpet.
Unread 23-04-2012, 09:42
Andrew Lawrence
Posts: n/a
I hear it's pretty grippy, and wears really well....but that's it. If you get into a pushing match with roughtops vs. nitrile, both with similar gearboxes/speeds, you're not going to find one will be drastically better than the other.
If you don't think it's worth the hassle, just use roughtop/colsons. You're not going to loose any needed power.
Unread 23-04-2012, 09:54
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Just to clarify. Nitrile is a material while roughtop is a tread pattern. You can get nitrile roughtop or neoprene roughtop or a couple other rubbers. Nitrile is just about the least grippy of all the potential materials but not by much and its wear characteristics are much better than some of the other materials. That said...I still prefer colsons.
Mentor 2415
Unread 23-04-2012, 09:58
AKA: noops
Originally Posted by sdcantrell56 View Post
....That said...I still prefer colsons.
Of course, the only thing preventing me from using colsons is the time and financial cost of making your own live axle hubs for them.
Unread 23-04-2012, 10:31
AKA: Justin Foss
The financial cost of making your own live axle hubs for colson wheels is actually relatively low. I'd argue less than the cost of buying other types of wheels. See FRC228.
You want a simple live axle plug for the colsons 1.5" wide, buy a piece of 1.25" OD diameter aluminum rod, turn down to 1.2" inches OD, drill thru and broach for whatever you want to drive, and cut to 1 5/8" long. Press in, and drive.
Or just wait a few months, I hear that WCP will be selling live axle plugs in the future.
