Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 23-04-2012, 12:13
Re: Rule clarification (pneumatic solenoids in series)
Originally Posted by Madison View Post
Sean,
Our entire catapult system is relies upon running solenoid valves in series. We've never had any trouble with inspectors; we just need to show them that each port on our cylinders is connected to only one valve.
We learned a lot about the pneumatics rules trying to inspect your robot. I think two of the inspectors rock-paper-scissor-ed for it.
[R78] The outputs from multiple valves may not be plumbed together into the same input on a pneumatic cylinder.
My interpretation is that if you only have one output plumbed to the input, this rule is satisfied.
Unread 23-04-2012, 12:35
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Hailey 0 sean 1
Unread 23-04-2012, 19:17
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
Couldn't you achieve the same result by pressurizing both sides of the cylinder equally? Only problem I can see is that it would be a bit less air-efficient.
EDIT: Never-mind, I just remembered how physics work...
