Go to Post Achieving a goal by merely finishing, or reaching mediocrity is not acceptable; Excellence is the only satisfactory result. - AdamHeard [more]
Unread 09-01-2003, 15:38
frumious frumious is offline
frumious is an unknown quantity at this point
Send a message via ICQ to frumious Send a message via AIM to frumious Send a message via Yahoo to frumious
I'm fairly sure using the bernoulli principle would fall under the 'custom pneumatic components' section, anyway. I think the only way to make a vacuum legally involves actuating one pneumatic cylinder with another, creating a vacuum air connection of the cylinder being moved. If you attach this to a decent suction cup, you should be able to form a vacuum between that and any surface.
Tyson
Best use of suction cups in Galieo? Spikey Championship Event 3 21-04-2003 20:36
pic: Team 870 Suction Cups CD47-Bot Robot Showcase 45 29-03-2003 22:48
Q&A Discuss: Suction Cups CD47-Bot Extra Discussion 14 27-03-2003 18:04
Image Discuss: Our anchor is more powerful than you bot CD47-Bot Robot Showcase 31 22-02-2003 21:00
Suction Cups Lauren Hafford General Forum 4 06-01-2003 00:01
